rough running low power 00 7.3
Discussion in 'All Other Diesels' started by Joey D, Dec 28, 2008.
  1. Joey D
    Joey D Member
    524
    1
    Nov 25, 2008
    My 450 started running like crap today, idle is low, rough running until rpms come up and no power.
  2. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    4
    May 5, 2008
    NE Ohio
  3. Joey D
    Joey D Member
    524
    1
    Nov 25, 2008
    I will change it today to be sure but it has less than 2000 miles on it.
  4. Diesel Decals
    Diesel Decals The Decal Man
    119
    0
    Nov 9, 2008
    check the oil sounds stupid but theres a safety when the oil gets low they dont run well
  5. Joey D
    Joey D Member
    524
    1
    Nov 25, 2008
    I checked the oil and swapped out the fuel filter, I drained the bowl before putting in the new element. Starrted up and it's much better. I am going down to drive it around and see if it is fine.
  6. Clark20ry
    Clark20ry Agent #58 OB-DII A(ALCU)
    1,679
    0
    May 5, 2008
    Surprise AZ
    My neighbor just found out that oil level is very important. His 7.3 ran real rough when cold but got better as it warmed. It finally died the other day he did some research and found out that the (forgive me if its a little vague) there is a high pressure oil pump that creates the fuel pressure (fords equal to the CP3). He was real low on oil so it just was not able to build enough fuel pressure. He added a whold gallon (it leaks) I heard it fire up shortly after he charged both batteries. So be sure to check your oil.... :thumbsup:
  7. Golddigger
    Golddigger New Member
    154
    0
    May 11, 2008
    Northern Utah
    There is an expensive repacement for that HUEI pump. It is supposed to be way better and manage the oil pressure better. I think is 2 machined to go back to back.
  8. Joey D
    Joey D Member
    524
    1
    Nov 25, 2008
    Now it goes back and forth between running fine then running like crap.
  9. Golddigger
    154
    0
    May 11, 2008
    Northern Utah
    They did have injector harness issues with the 7.3. You might check your dealer for info.
  10. Joey D
    Joey D Member
    524
    1
    Nov 25, 2008
    I swapped out the injector pressure sensor and it solved it. Thanks for the help
  11. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    what a idiot! how do you not keep an eye on your oil!!!
  12. Justin, the irrigation company I used to work for had a 91 or so F-Super Duty with a really wore out Navistar 7.3L IDI (non turbo) backed by a wore out 5-speed. The truck had a utility box and boom for pulling/setting submersibles, it would burn at LEAST a gallon of oil going out to a job, working, and coming back. That's a 50 mile round trip. That's if I babied it, if I kept my foot in it the EPA would pick it up on a satellite and get pissed...when I worked there I'd add up to 2 gallons, depending on how it was driven.
  13. jcool
    1,097
    0
    May 4, 2008
    Richlands, NC
    um... wow.... thats more than burning/ leaking oil.... it would have been cheaper to fix it than keep throwing oil at it!
  14. It smelled horrible idling. The cloud of smoke that it gave off was NOT soot. If it hadn't been ran in a while and was 40 degrees or less outside I had to give it a shot of WD-40 in the air intake to get it to start. It was wore out, I'm not kidding...I think it had ~170k miles on it.
  15. jcool
    1,097
    0
    May 4, 2008
    Richlands, NC
    was it poorly maintained or just a bad apple? that thing should have gotten a lot more mileage on it than that!
  16. Brooklyn Tow
    Brooklyn Tow 9 11 Never Forget
    3,212
    4
    May 6, 2008
    Brooklyn, NY USA
    Does 94.5 (first year powerstroke) have a injector pressure sensor?
    Location please
    Thanks,
Share This Page
