refill after filter change
Discussion in 'GM Allison' started by 07.5 Chevrolet, May 16, 2008.
  1. 07.5 Chevrolet
    07.5 Chevrolet New Member
    7
    0
    May 15, 2008
    Coming up on 5K miles and decided to change the trans filter. How much fluid will I lose during this? I assume quite a bit?
    an 07.5 LMM.
  2. BudTX
    BudTX Edjumacated Redneck
    Pre-fill the new filter, and you won't lose much. Maybe a shot glass worth.
  3. 07.5 Chevrolet
    7
    0
    May 15, 2008
  4. BudTX
    You probably already know this, but don't forget to save the little donut magnet from the top of your old filter. You will want to clean it off and reuse it with your new filter. :)
  5. WhtThndr3
    WhtThndr3 Yeah, I'm that guy
    Stoopid question, i changed my filter, and the dealer gave dex VI to put in as fluid. Is this the right stuff?
    Sub questions, I've seen alot of transsynd stuff as a fluid for Ally's. Should I have used this? And is it a good synthetic replacement for the ally? How does it compare to amsoil, better?
    Thanks.
  6. BudTX
    I believe that Dex VI is the right fluid for your '08. Your owners manual can tell you for sure.
    I went to Transynd when I had my tranny built. It is top-tier stuff, but it ain't cheap.
  7. Wrecker
    Wrecker The Oil Geek
    Dex VI is correct for '06 and later. Amsoil ATF is a great choice, wholesale pricing from The Oil Geek available to all.
  8. WhtThndr3
    Cheap ain't no problem. Not for my baby.
    I'm a preffered member. I'm assuming you offer the same prices?
  9. Wrecker
    Correct, I can only sell as cheap as I can get it.
  10. WhtThndr3
    When's a good time to change out your tranny fluids? I tried to get bubba to change my dif's but he said they already had stock synthetic. Is that a load of crap too?
    I'm at 7k miles
  11. rtquig
    rtquig New Member
    123
    0
    May 13, 2008
    Forked River, NJ
    Your rear diff. should have been changed out already. It reaches very high temps during initial breakin period. Get a good synthetic and change it out, a little under 4 quarts.
  12. Wrecker
    Now is a good time to change diff fluid if you are at 7k miles. I did mine at 5k. Many factory fills are less than full and the fluid will be NASTY by now. Do your self a favor and change it, new dino is better than the break in junk you have in there right now.
  13. WhtThndr3
    Thank you, I'll tell bubba to just take my money as shut up:mad5:
Share This Page
