Rebuilding my tbi 350
Discussion in 'Any Other Gas Engine' started by tanman_2006, Mar 1, 2018.
  1. tanman_2006
    tanman_2006 Just a farm kid...
    5,498
    508
    Feb 15, 2010
    Seiling, Oklahoma
    If I wanted to get a port and polish job done on those hybrid heads would it be worth my time?
  2. btfarm
    btfarm 325,000 Worth Staff Member Moderator
    16,532
    2,208
    May 12, 2008
    Sandwich, Illinois
    We do now have Chris of Twisted Steel as a vendor. Ask him if he does gasser heads.
    tanman_2006, Jaryd and NVW like this.
  3. Jaryd
    Jaryd Oh the sound a 6.5 makes
    628
    758
    Nov 27, 2016
    Hodges, SC
    I was going to suggest the same thing.
  4. tanman_2006
    5,498
    508
    Feb 15, 2010
    Seiling, Oklahoma
    Good idea. What is his screen name again? Is he a vendor?
    MrMarty51 likes this.
  5. NVW
    NVW Well-Known Member
    8,631
    1,178
    May 5, 2008
    Castor, AB.
    Look at the top of the page where Leroy Diesel and Rock Auto adds flash, screen name is sctrailrider
    MrMarty51 and tanman_2006 like this.
  6. tanman_2006
    5,498
    508
    Feb 15, 2010
    Seiling, Oklahoma
    @THEFERMANATOR Do recommend you stock ratio roller rockers or something else with the cam you suggested?
    The Clearwater heads sound like the way to go, more meat should mean less risk of cracking.
    Would I have to upgrade the intake and tbi right away? Only curious since I dont have many miles on my current injectors, I also have heard the 454 has idle issues on 350 engines.
  7. tanman_2006
    5,498
    508
    Feb 15, 2010
    Seiling, Oklahoma
    Sent him a FB msg. I remember a couple of his builds, always liked the outcome.
  8. Twisted Steel Performance
    Twisted Steel Performance Formerly: sctrailrider Vendor
    1,610
    1,168
    Jan 15, 2012
    Pauline, SC
    Tanner you might want to read through some of my info threads in my vendor thread and get a idea of what coating do, you could benefit from a few of them...
  9. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    There's no need to run anything more than 1.5:1 rockers. Vortec, swirl ports, and even the hybrid heads all pretty well max out airflow around .500 lift. Vortec heads were specifically designed to flow almost max at .400 lift so GM could run a small cam with them. You could run your stock intake and throttle body no problem. i only mention upgrading them because they would be limiting peak output instead of your heads. As to some saying they have problems with the 454 tbi unit on small blocks not running right, I think this is from lazy tuners. GM turned out THOUSANDS of 4.3, 5.0, 5.7, & 7.4's in marine use, and they ALL got the same TBI units bolted on them. GM used the same 2" bore throttle body and 85 lb/hr injectors for low pressure, or 45 lb/hr injectors for the high pressure systems. And they had zero issues with any of those engines running/idling poorly. Even the 4.3l running 40 psi of fuel pressure on the 45 lb/hr injectors(comes out to around 110 lb/hr by increasing the pressure) would start, idle, and run just as smooth as could be asked for. So I don't see why others have problems on the street.
    tanman_2006, btfarm and MrMarty51 like this.
  10. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    The more I've thought about your build, the more I would lean towards using regular enginequest ch350c heads. Everything I've read says they fixxed all the GM shortfalls and improved the exhaust ports as well as screw in studs coming standard. Run the edelbrock performer eps 2716 intake with a tbi adapter plate(and by goi,g this route, if you decide to run a 454 tbi unit, all you have to do is bore out a 1/2" thick adapter plate instead of boring an intake). You may have to rework a bracket or 2, but it wouldn't be a hybrid compromise head/intake setup, but instead a proven combo. There isn't much feedback out there on the hybrid heads, and the only tbi build I could find was said to have alot of problems(I found many people with them in boats with carbs that said they loved them, but the negative reviews about tbi concerns me).
    A&A midwest is the company that builds and retails the heads. They're priced about the same as clearwater, and are in Arizona I believe. I would hate for you to get this combo together, and have it not run right is all.
  11. tanman_2006
    5,498
    508
    Feb 15, 2010
    Seiling, Oklahoma
    Still think comp cam's 249-08-530-8 cam is the way to go?
  12. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    That looks like a decent price on the enginequest heads considering they put lt1 springs in them. I'm sure there is other good cams, I can only speak from my experience that this particuliar cam has an excellent power band, plays nice with stock fuel injection, stays under the .480 lift limit, and pulls like a son of a gun. It's power band is a bit weak below 1500, but at 1500 it starts pulling, and just keeps going all the way up to redline in the trucks I've put it in. I know alot of guys like runni,g the gm hot cam, lt4 cam, and other aggressive cams which are fine for a sport truck, but when you're building one to tow, match the cam's power band to where you'll be running, and not go with a cam that has no guts below 2500 and wants to wind up to 6500. I don't know about you, but I don't know many engines that are long lived running those rpm's while being worked.
Share This Page
