Quick part check reference (Is XXXX part good?)
Discussion in 'GM 6.5 Diesel Engines' started by monel_funkawitz, May 8, 2008.
  1. monel_funkawitz
    monel_funkawitz Recruit
    36
    0
    May 7, 2008
    This thread is started as a way to keep info clear and concise in checking a part on the 6.5 that you suspect is bad.
    6.2/6.5 Glow Plug Controller (AKA Glow plug relay)
    Single big heavy red wire terminal - Should have battery voltage on it all the time.
    Double big heavy red wire terminal - Will have battery voltage on it when glow plugs are on. This connects directly to the glow plugs.
    Pin A - Not connected
    Pin B - Will have battery voltage when key is in start position.
    Pin C - Will have battery voltage when glow plugs are on.
    Pin D - Will have battery voltage when key is in run position.
    Pin E - Is connected to ground.
Share This Page
