Power mirror won't retract????
Discussion in 'Exterior' started by 03WIDEMAX, May 13, 2008.
  1. 03WIDEMAX
    03WIDEMAX BFT
    87
    0
    May 12, 2008
    Greendale, WI
    Glad to be here fellas, but I have a problem with my morror to address:confused5: My right side mirror will move sometimes, right now its stuck all the way out. Any idea's where I should start for troubleshooting?
  2. Give it a gentle shove back in a bit and see if it will retract. If so then run it all the way in and back out several times.
    There's also a little clutch adjustment inside the mirror that may need to be tightened. I fought this continually on my '03 and two new mirrors installed on warranty. Didn't help much...
    Best solution that I had was spraying the rubber boots with 303 pretty often to keep them soft. Seemed to make just enough difference so they'd work most times.
    HTH
  3. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    my right side mirror did the same thing this winter. i think there must have been some moisture in there causing problems when it was cold. i just shoved it in when it wouldn't retract. worked fine after it warmed up a bit. don't have that problem any more with my new tow mirrors.
  4. 03WIDEMAX
    03WIDEMAX BFT
    87
    0
    May 12, 2008
    Greendale, WI
    Thanks guys, I will give those a try:thumbsup:
  5. Diesel Dually
    Diesel Dually awaiting your return...signed... your friends
    506
    0
    May 3, 2008
    Mile High
    Time for '06 mirrors...;)
  6. busdriver75
    1,258
    0
    May 7, 2008
    NW Ohio
    x2. once you get 'em on there, you'll wish you did it earlier.
  7. michael nelson
    michael nelson diesel addict
    954
    0
    May 3, 2008
    san diego,ca
    I give mine a little bump and the work great after that...any one got lube points w/pics and lube suggestions please post-...good sticky-just a thought
  8. michael nelson
    954
    0
    May 3, 2008
    san diego,ca
    or tell me where to lube and such and I will take the photo's and post-
  9. busdriver75
    1,258
    0
    May 7, 2008
    NW Ohio
    i think you have to take the mirror off, pop the mirror out so you can get the plastic expanding piece off, then clean and grease. there was a thread on some other site, but i can't remember who posted it. they might be over here already.
  10. 03WIDEMAX
    03WIDEMAX BFT
    87
    0
    May 12, 2008
    Greendale, WI
    New mirrors are a low priority right now. I will take the mirror apart and lube. I'll try and rememer to take pics too. :smileydan:
  11. Smokin LB7
    Smokin LB7 Just Takin' it From a Dig
    34
    0
    May 13, 2008
    Greeley, CO
    what is the difference between the two?
  12. Smokin LB7
    34
    0
    May 13, 2008
    Greeley, CO
    Please do because mine are doing the same thing. So I would love to see pics of what you did
  13. Cheyenne19
    Cheyenne19 Special agent C19 A(ACLU)
    540
    0
    May 4, 2008
    The Delta
    My power folding crap quit a long time ago.
  14. Reineke
    Reineke New Member
    16
    0
    May 13, 2008
    I make sure to move the mirrors in and out quite often. I try not to keep them in the same position very long and have had no issues. I live on a gravel road, so they do get pretty dirty.
  15. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I don't know why but I love the '08 super duty mirrors...that'd be cool to make those work on a chubby
  16. Pepperidge
    Pepperidge Member Advocate Staff Member Lead Moderator
    12,367
    364
    Feb 10, 2008
    Slidell, La
    yeah it's not the mirrors on a Ford thats the problem...it's everything else attached to them...:D
  17. 05lly2500hd
    05lly2500hd Recruit
    67
    0
    May 5, 2008
    My 05 camper mirrors did the same a LONG time ago...Passenger side would extend but not retract unless I had someone to give it a push.
    I like the new mirrors a lot.
  18. Golddigger
    Golddigger New Member
    154
    0
    May 11, 2008
    Northern Utah
    The '06 mirrors are not the accordian style. They are similar to the ford mirrors: View here gm parts direct.
    I did not do it as a link cause I was not sure if it was ok.
    GM PART # 15904034 & 15904035
    CATEGORY: All
    PACK QTY: 1
    CORE CHARGE: $0.00
    GM LIST: $335.00
    OUR PRICE: $205.54
    DESCRIPTION: 2006 FULLSIZE TRUCK EXTENDING MIRROR LH
Share This Page
