Over/underdrive
3bals
Active Member
Likes
149
Minnesota
Thread starter #1
Years ago I was looking at installing a 2 speed gear splitter on my K2500. I had located one that goes between the transmission and the transfer case, that way you could use it in 2X4 and 4X4 (not like gear vendors that only work in 2X4). I never pulled the trigger, but now am thinking of installing one in my Jeep XJ and now I can't find them. Does anybody have a link?
schiker
Likes
515
Pendleton, SC
#5
Have you called Gear Vendors and asked about a customized unit for in between the transmission and transfer case. They can do that too.
From their website
"Fact is, when you are in 4X4 there is very little desire to use GearSplitting and overdrive unless you are racing (and we do make the in-between kit for that purpose), "
"US Gear Ranger" the "Nash overdrive" is no longer made that I know of.
I'd like to know how exactly the GV works and feels.
I believe they have to have a minimum speed to shift up. I don't know but will they automatically downshift if the minimum speed is not maintained ???? How long does it take to shift up or down? Can the downshift be locked out until desired?
The split shift that interests me is the NV4500 2-3 gears. How fast would you have to get in 2nd to split shift? Stock with 3.73's when towing uphill I have to rev 2nd to ~3-3200 rpm to get into 3rd without lugging 3rd.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
Likes
2,536
ZEPHYRHILLS FL
Staff #7
US gear was the one that mounted in between, and went out of business quite awhile ago now(almost 10 years now I believe). The gear vendor is also called a laycock overdrive. Volvo factory installed them back in the 70's. They need about 10 mph ground speed to have enough rpm's for the pump in it to hydraulically engage the cone clutch. Cone clutches are nice in that they require very little pressure to engage, they actually pull the clutch together tighter under load. But they have very little reverse holding power(like in engine braking, you cannot do that with them).
