Oil filter crushed and stuck
Discussion in 'Maintenance & Fuels' started by jhornsby3, Mar 27, 2011.
  1. jhornsby3
    jhornsby3 New Member
    309
    0
    May 18, 2009
    Boise, Idaho
    As stated above the filter is stuck on. Broke the filter wrench and crushed the filter housing. Need to get this off so I can get the system flushed of coolant. What would be the best way to get that filter off the block. Dang I'm thinking of going back to the gassers more now.:rolleyes5:
    John
  2. SmithvilleD
    SmithvilleD Active Member
    909
    106
    Mar 2, 2009
    Smithville, MO
    Sometimes you can get them off with a large enough Channel-Lok if there's room to grip the base where it's thicker/the lip is folded over.
    Can also always try poking a screw driver thru the sheet metal filter sides & trying to turn it that way - although I've not had much luck with that. Many/most modern made filters have such thinwall metal that the screw driver generally tears it before the filter turns.
  3. jhornsby3
    309
    0
    May 18, 2009
    Boise, Idaho
    Filter housing tore right at the lip. That and the thin metal is so smashed that I would be afraid of it coming off the lip completely. I'm going to remove the adapter from the block and put it in the vise as advised on another forum.
    Thanks,
    John
  4. SmithvilleD
    909
    106
    Mar 2, 2009
    Smithville, MO
    Can you get enough of the outer tin & crap torn off to then use a punch & tap on the little oil flow holes on the base & turn it off that way?
  5. Turbine Doc
    Turbine Doc Just Another Diesel Guy
    SHARP Chisel on outer rim lip @ base if you can't achieve what Smithfield recommends, it's a K2500 worst case you drop front drive shaft, pull the center nut out of oil filter 4x4 adapter and pull adapter assy, it probably needs new o-rings anyway 36mm or 1-3/8" socket to remove the 4x4 adapter 1-3/8" is a little sloppy fitment
  6. bison
    bison Well-Known Member
    I had good luck using a hammer and blunt screw driver on the rim, a chisel has the tendency to cut trough without moving the rim.
    with a screw driver you maintain a bite without cutting trough.
    Nowadays I use a narrow 1/4" wide filter wrench with teeth on the jaws.works kind of like a pipe wrench and place that on the filter against the rim.
    Haven't had a filter yet that wouldn't budge.
  7. mangus580
    mangus580 Member
    316
    1
    Jun 3, 2008
    Western NY
    Dad actually welded up a spanner wrench once, that fits the hole in the oil filter... worked like a champ!
  8. jhornsby3
    309
    0
    May 18, 2009
    Boise, Idaho
    Thanks all for the replies.
    Got it off. I tried the chisle nothing, then the screw driver. Both just cut the lip around the end. Called a friends and he had, believe it or not, a damaged filter removal tool. It grabs the sheet metal and crushes into it spinning the metal till the filter comes off.
    Tried to get the bolt off on the adapter but no go. The socket had too large a lip on the end and the bolt head was just to thin. I have the o-rings and all so that will be done in the near future as it is weeping oil.
    Again thanks,
    John
  9. WarWagon
    WarWagon Well it hits on 7 of 8...
    7,397
    1,382
    Nov 15, 2009
    AZ
    Gassers leak at this adapter too...
    Only 1/4 turn is needed after gasket contact.... Jiffy Lube or dealer with an impact putting that filter on?
  10. JMJNet
    JMJNet Recruit
    1,916
    84
    May 6, 2008
    Richardson, TX
    Glad that you take it off.
    What brand of oil filter that is crushed? I hope it is not Fram Orange?
    How does damage oil filter wrench looks like?
  11. RI Chevy Silveradoman
    RI Chevy Silveradoman At your service Staff Member Moderator
    9,751
    470
    May 3, 2008
    Rhode Island
    Glad to hear that you got it off. Any photos of the filter removal tool?
  12. jmack91z28
    jmack91z28 Jason
    146
    6
    Jan 28, 2011
    Midland, NC
    I've never understood why people torque the piss out of oil filters. I do the same as WarWagon, 1/4 turn or so after gasket touches. I've never needed to use a filter wrench to take one off that I put on. Also never had one leak oil or vibrate loose either. Applying some oil on the filter gasket before installation helps a lot with removal later on as well.
    Glad to hear you got it off, sounded like you had a huge issue if it didn't come off.
  13. RI Chevy Silveradoman
    9,751
    470
    May 3, 2008
    Rhode Island
    Same here. Hand tight was how I was taught. Never had a leak either. It goes on hand tight. And you usually need two hands to remove it. Go figure.
  14. trouttrooper
    trouttrooper Big Blocks ROCK!!!
    1,865
    48
    Jun 17, 2008
    Nampa, ID
    Here's my experience with Jiffy Lube. Once, go to change the oil on dad's car and I had to do the screwdriver through the filter housing trick 2 FULL TURNS before it was loose enough to unscrew by hand. Second, get oil changed in my work truck. 50 miles later I get low oil pressure warning. They didn't put the filter on all the way, I pumped it all out driving down the highway.
    Gee, any wonder why I do my own vehicles.
  15. jhornsby3
    309
    0
    May 18, 2009
    Boise, Idaho
    It was a walmart brand filter. I was running the oil in the truck for a few days to flush the remaining coolant out of the motor from the head gasket issues I've been having. This was the third filter to go on and I put it on just tight enough to feel a little resistance but not over tight. The gasket had come loose from the filter body and was stuck on the mount. All three of the filters had the gasket come off and hang up. I plan on using the STP filters for this go round to flush the system out. I just wanted the cheapest filter seeing as it was only going on for 50 miles or so.
    The tool was like the filter wrench that grabs the end of the filter but it ratcheted tight around the end and crushing it more/onto itself. You can then just twist the filter housing till the filter spins off. I should have taken pix of the filter before I tossed it to go out this morning.
    We'll see how this round of head gaskets goes. I plan on just taking them down to be skimmed and remove that from the list of could be's. I just want this to go back together and be able to be driven.
    John
  16. RI Chevy Silveradoman
    9,751
    470
    May 3, 2008
    Rhode Island
    Thanks for the updates. Good luck with the engine flush.
  17. JMJNet
    JMJNet Recruit
    1,916
    84
    May 6, 2008
    Richardson, TX
    STP and ST are the same filter, unfortunately. Get the cheapest NAPA white filter or the Purolator white, they are well made and cheap, may be cheaper than STP .
  18. jhornsby3
    309
    0
    May 18, 2009
    Boise, Idaho
    NAPA here is very spendy. They wanted 5.99 for the cheapest filter. I haven't seen a Purolator filter in years. I'll check around for the next round of flush when I get the heads off and back from the shop. I'll be flushing oil through it two more times before I put the synthetic back in. And she don't like that dyno oil at all. Sounded like a tin can full of marbles when cold.
    John
  19. JMJNet
    JMJNet Recruit
    1,916
    84
    May 6, 2008
    Richardson, TX
    Don't get the Napa Gold, which they usually promote. The cheapest one is called Napa ProSelect and it is behind the counter, at least at both Napa that I go to here.
    Purolator is usually available at Advance or PepBoys or Sears.
Share This Page
