New GM 6.5 TBD owner in YT
Discussion in 'Introductions' started by SmashfistMcTip, Jun 5, 2018.
  1. SmashfistMcTip
    SmashfistMcTip New Member
    Hey everyone,
    Just bought a '95 GMC 1500 with the GM 6.5 TBD (my first diesel) in Calgary and soon will be driving it home to YT. Just working on some preventative maintenance and getting it in shape for the drive home!
    BIGR and Jaryd like this.
  2. Will L.
    Will L. Well-Known Member
    7,554
    6,330
    Jan 25, 2013
    Boulder City Nv
    Welcome. Remember that a spare pmd is like a spare tire.
    How far is your trip?
  3. Jaryd
    Jaryd Oh the sound a 6.5 makes
    719
    915
    Nov 27, 2016
    Hodges, SC
    Check all fluids. Change filters and like Will said, get a spare pmd before the trip if you can.
    You will enjoy owning a 6.5.
    BIGR likes this.
  4. BIGR
    BIGR Lucky To Be Here
    5,419
    3,018
    Jun 9, 2008
    Appalachian Mountains
    Welcome to The Truck Stop.
    Jaryd likes this.
  5. snarl95
    snarl95 Active Member
    351
    212
    Feb 22, 2014
    Edenton,NC
    welcome
    Jaryd likes this.
  6. smokymtn65
    smokymtn65 Well-Known Member
    315
    459
    Aug 21, 2015
    East TN
    1400 mi or so, bet that is a beautiful drive at the right time of the year! Welcome, Just turned 4000 + miles in a week at the end of March and didn't need any of my spare truck.... I mean parts that I carried! Thank the Good Lord!
    Jaryd and Will L. like this.
  7. SmashfistMcTip
    Yeah it's about 3000km (roughly 1500 miles).
    It came with a spare PMD, and it's mounted I think between a battery and headlight, I just need to familiarize myself with that before I leave. All fluids checked/changed, all good except oil and coolant. Flushed the coolant system and put in a 180F thermostat. Changed oil but put too much additive (Lucas oil stabilizer and stop leak) and the oil pressure went way up, another oil change and that has mellowed out, although I don't honestly trust any of the gauges... I'm going to clean all the grounds this week and hopefully get some more accuracy on them (and a lower reading on oil pressure!).
    The oil pressure thing was scary but I think it worked out in the long run... Running it for a bit with the additives seems to have dramatically slowed some leaks and lowered blowby. I also, perhaps foolishly/riskily, used a well-reviewed, German diesel specific fuel system cleaner; I put their mellower cleaner into the tank with a fill-up and then halfway through the tank put their more intense cleaner into the fuel filter by sucking out the diesel and filling back up with this. Did that twice and then threw the rest into the tank... also very slowly poured a Lucas diesel fuel system cleaner into the air intake between the turbo and the air filter... I know this was all a gamble, but it paid off; the thing blew out a bunch of gnarly smoke and now it runs waaaaaaay smoother, especially at idle, smokes less and for shorter... I did the second oil change after this process so anything that the oil picked up hopefully is now gone!
    I just need to get it home where I have my shop/tools to really address anything necessary!
    Next is making sure the trailer brake controller works (never had/used one before) and checking the air bags in the rear suspension!
    Thanks everyone for the warm welcome, I'm sure I'll have some dumb questions for y'all in a little bit! I'm a modest backyard mechanic but this is my first diesel so still wrapping my head around the major and more insidious differences!
  8. ak diesel driver
    ak diesel driver 6.5 driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    95 will rely on the oil pressure sending unit to power the lift pump (under the driver's seat). Maybe take a spare and another LP.
  9. ak diesel driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    What part of Yukon are you in?
  10. SmashfistMcTip
    Carmacks, two hour north of WH.
    I'm not sure what you mean... I thought oil pressure sending (OPS) unit is fancy pants for a sensor that sends the gauge or light info about how oil pressure is doing... Do you mean that power for the LP is somehow wired through or runs through the OPS?
  11. Will L.
    7,554
    6,330
    Jan 25, 2013
    Boulder City Nv
    Yes. It send signal to the gauge and also sends power to the lift pump so if you crash, when engine stops so does lift pump. Order a harness from leroy to add relay inline and have switch to prime filter sfter changes.
    The ops is hard to reach when it dies. In the valley.
    Jaryd likes this.
  12. btfarm
    btfarm 330,000 Worth and counting Staff Member Moderator
    16,603
    2,383
    May 12, 2008
    Sandwich, Illinois
    Welcome To the Truck Stop!
    Jaryd likes this.
  13. ak diesel driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    Been through carmacks many a time
  14. SmashfistMcTip
    On vacation and whatnot? You need anything from Calgary?
  15. ak diesel driver
    12,847
    2,871
    Feb 7, 2009
    alaska
    We may almost be neighbors but it's still along ways. LOL Been over the Alcan probably 50 times
Share This Page
