My weekend project.
Discussion in '04.5-05 LLY' started by SEA04DMAX, May 5, 2008.
  1. SEA04DMAX
    SEA04DMAX Recruit
    21
    0
    May 5, 2008
    Well i installed the gm 6.5L Lift Pump and micron filter setup today. I uses all 1/2 inch fittings and hose also i fabbed up a custom braket. I will post some pictures later. The Rail Pressure holds at 21,000 @ 2900us, I would say that is good enough for me. That tune sends the tires to smoke when it shifts into 2nd.:twisted:
    [​IMG]
  2. RI Chevy Silveradoman
    RI Chevy Silveradoman At your service Staff Member Moderator
    9,949
    704
    May 3, 2008
    Rhode Island
  3. WeedNemesis
    WeedNemesis A Weed's Worst Nightmare
    55
    0
    May 4, 2008
    Columbia, MO
    Looks good. Does it go: Tank -> Lift Pump -> Filter or am I backwards? Also were you having trouble keeping the CP3 fed or is it more for insurance?
  4. SEA04DMAX
    SEA04DMAX Recruit
    21
    0
    May 5, 2008
    It comes from the tank to the pump , filter, then to the line that feeds the engine. I was losing rail pressure on bigger tunes and the filter is just an insurance policy.
  5. pc_renaud
    pc_renaud Member
    95
    1
    Jul 18, 2008
    Ct
    What was the cost on the lift pump and where did you get it?
  6. Tow Master
    Tow Master New Member
    235
    0
    May 15, 2008
    Irwin, Pa
    Huh it looks like a good idea! If you just wanted more fuel pressure why did you add the filter?
    Good idea though! Its definatly cheaper than doing twins. IIRC the inline pump was like $100?
  7. SEA04DMAX
    SEA04DMAX Recruit
    21
    0
    May 5, 2008
    I bought the pump for 140.00 but the pump can be had at your local auto parts for 50.00. I bought the pump from Kennedy because i wanted the 1/2 inch fittings that came with it.
  8. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    5
    May 5, 2008
    NE Ohio
    I never knew that you Duramax guys used 6.5 parts. Very neat!
Share This Page
