May have found a new wireless temp probe
Discussion in '6.5 Performance' started by Sand, Apr 10, 2018.
  1. Sand
    Sand Active Member
    183
    183
    Mar 27, 2016
    Canada
    Im going to grab one of these ffro Home Depot.
    Weber iGrill Mini App-Enabled BBQ Thermometer
    200hr battery life. Smartphone app.
    Ill put it in my transfer case to start. Then move it to my diff and even throw it in my geared Hummer hub.
    Monitor temps from the cab wirelessly.
    Its only 50 bucks....
    n8in8or, MrMarty51 and jrsavoie like this.
  2. Sand
    Sand Active Member
    183
    183
    Mar 27, 2016
    Canada
    32-500 deg.
  3. smokymtn65
    smokymtn65 Well-Known Member
    246
    311
    Aug 21, 2015
    East TN
  4. Twisted Steel Performance
    Twisted Steel Performance Formerly: sctrailrider Vendor
    1,610
    1,168
    Jan 15, 2012
    Pauline, SC
  5. Sand
    Sand Active Member
    183
    183
    Mar 27, 2016
    Canada
    1/8 npt cable gland tightened around the probe. Then threaded into the transfer case. Possibly at the drain plug. It not for permanent use. Just to see where things operate at. My transfer case has a cooling loop from the transmission. I think it acts as a transfer case "heater" most of the time. As well im curious what temps my hubs run at under load.
    n8in8or and smokymtn65 like this.
Share This Page
