Long A/C Compressor vs. short A/C compressor
Discussion in 'GM 6.2 Diesels' started by Landon730, May 9, 2018.
  1. Landon730
    Landon730 Member
    51
    34
    Aug 7, 2017
    Greenwood Arkansas
    I have a 84 6.2 square body with A/C but I can't decide to keep this compressor or get a short smaller one like on the early 6.5. Is there any advantages to the longer one?
  2. THEFERMANATOR
    8,978
    2,302
    May 9, 2008
    ZEPHYRHILLS FL
    If it was mine, I would do the sanden 507 swap. The harrison pancake compressors are nice for compact installations, but reliability with r-134 hasn't been the best with them. And the early styles are said to be very good, but take up alot of real estate. The Sanden 507 is very reliable, used all over, and is in between the 2 in size. That would be my suggestion if your looking to change.
    MrMarty51, WarWagon and Will L. like this.
  3. WarWagon
    WarWagon Well it hits on 7 of 8...
    8,156
    2,528
    Nov 15, 2009
    AZ
    I wouldn't willingly put a early 6.5 POS R4 "pancake" compressor on anything. Keep what you got or use the suggested even better Sanden 507 because it's light years better than the R4 leakmaster grenade. The R4 was a POS even with the low head pressures and better oil flow of R12. The only way I get a R4 to live beyond the miserable 2 year warranty is to evac and charge the system every year and run alternate refrigerant.
    MrMarty51 likes this.
  4. Landon730
    Landon730 Member
    51
    34
    Aug 7, 2017
    Greenwood Arkansas
    Ok so my main question is which one gets colder lol? I don't care about real estate, thats not why I wanna change it, just want the one that works better.
  5. WarWagon
    8,156
    2,528
    Nov 15, 2009
    AZ
    Sanden 507 or yours and IMO the Sanden is the more modern and efficient unit. The R4 is inefficient turning HP into heat the heat has to be removed from the condenser or the AC doesn't cool well - HP draw be dammed. You want to focus on cooling the condenser to get the AC cold. The engine fan is just that and overheats the condenser till the engine warms up and gets the fan on. Suggesting the 454 aux cooling fan here that comes on with the compressor. Not sure if it fits the OBS of yours - so rig an electric fan to help the AC.
    If you want to ice up the evaporator, and I do even in 115+ weather on any less then high fan speed, run alternate hydrocarbon refrigerant. Without adequate condenser airflow even it will struggle. I need a evaporator temp switch to stop the freeze ups because GM regulates temp by pressure. R12/R134a Pressure has this stuff well below freezing before it kicks off. https://www.es-refrigerants.com/pro...6-ounce-can-equivalent-16-oz-134a/details.asp
  6. Will L.
    Will L. Well-Known Member
    7,396
    5,990
    Jan 25, 2013
    Boulder City Nv
    I’ll jump on board for the 507. And yes at idle electric fans can help, but I would rather see $ spent on TLTD coating the cooling stack. Here is why:
    Think how good ol r12 was then drop in the 134a and it could barely do anything. The “fix” was enlarged condensor by 33%. Exactly the ratio of r12-r134a exchange differences. Then people saw how much the bigger condensor did and added them to factory r134a systems and POW! ice in the face a/c.
    Now what ratio does TLTD affect the radiators, cac, etc? 33-35% depends on base material.
    No brainer imo. Put in the sanden for the long haul, and just as important coat the dang condensor instead of paint that holds in heat.
    MrMarty51 and WarWagon like this.
  7. deejaaa
    deejaaa Diesel Beginner
    1,639
    428
    Sep 19, 2008
    Texas
    is this info the same for my 93? i'm gonna want to get it going eventually and want to copy if it applies.
  8. WarWagon
    8,156
    2,528
    Nov 15, 2009
    AZ
    We really don't have the room on a 1993 to drop in a longer compressor. Swap the accessories brackets to a 96+ with the AC on driver side and maybe.
  9. deejaaa
    1,639
    428
    Sep 19, 2008
    Texas
    do ya mean swap brackets from a 96+? i have the complete 96 engine in the shop now with all brackets. would anything else need changing?
  10. WarWagon
    8,156
    2,528
    Nov 15, 2009
    AZ
    Yes. Need longer AC hoses - have them made. You have the altonator? Check the clearence on the t stat to AC. The tensioner is critical as the 1993 spring has to take the compressor load where the 1996+ doesn't and is a weaker spring.
    MrMarty51 and deejaaa like this.
  11. Twisted Steel Performance
    Twisted Steel Performance Formerly: sctrailrider Vendor
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
    Somewhere here their is a thread about using a sanden on 88-93's, and has the info for what brackets are needed... If I can find the thread I will link it, I also plan to swap a sanden this summer on mu 93 and need the info again...
  12. Twisted Steel Performance
    1,631
    1,204
    Jan 15, 2012
    Pauline, SC
  13. THEFERMANATOR
    8,978
    2,302
    May 9, 2008
    ZEPHYRHILLS FL
    You can run the sanden on the 93, but you have to move it furthur out to clear things. To swap to the 96+, you have to change all the accesories, tstat housing, hoses, try to clear the throttle bracket, and all that. Then you have the infamous belly leaker compressor. The harrison radial compressors aren't horrible, but they just are not holding up anymore.
  14. deejaaa
    1,639
    428
    Sep 19, 2008
    Texas
    i have everything that was bolted to the engine, except PS pump.
    i'll do some reading.
  15. Landon730
    Landon730 Member
    51
    34
    Aug 7, 2017
    Greenwood Arkansas
    Quick question - I can't get the blower to kick on and it looks like it was replaced not long ago. (Truck was last on road in 2008 lol) But anyways I THINK its the control head because the sliders feel pretty loose. Checked with a multimeter and we have voltage to the relay under the hood. Had to run a direct wire from a/c compressor to battery to charge the system. Blows cold air out the floor vent but whenever I use the sliders on the control head nothing changes.
Share This Page
