Little help with headlight adjustment
Discussion in 'GM 6.5 Diesel Engines' started by Crankme69, Nov 13, 2010.
  1. Installed new grill & light/marker assembly in the Tahoe yesterday.
    The 2 screws that protrude out the top of the headlight boxes are they the adjustment screws or are they they for something else?
    Gonna take another look at the old ones today & futz around with some more...
    Just thought maybe someone here could shed some light...literally LOL :)
  2. No worries I figured it out...thanks anyways!
  3. ak diesel driver
    ak diesel driver 6.5 driver
    11,475
    981
    Feb 7, 2009
    alaska
    my adjuster were siezed up when I tried to adjust them the first time. Took a little patience to get them unsiezed and lubed up.
  4. Mine are brand new...and they are easy enough to adjust, after I figured out what knobs to turn LOL
    Thanks AK yea the old ones are all seized up.
    Gonna work on the old ones see if I can free em up, they are going on the neighbors old 91. His are past seized & these ole ones will be an improvement over what he has on there now, he don't drive much at night, thankgod!
  5. chevyCowboy
    chevyCowboy I might be crazy but i ain't dumb
    1,590
    28
    Nov 16, 2008
    Springfield Nebraska
    so which nobs do what. i to just put new head lights in and cant figure it out. i figured out the up and down adjuster but what i cant seem to get to work is the left and right.
    thanks
  6. ak diesel driver
    11,475
    981
    Feb 7, 2009
    alaska
    here are the adjusters
  7. The adjuster far right (outer) is for horizontal position of the beam.
    The other one at bottom is for azimuth
  8. Big T
    Big T Well-Known Member
    2,894
    280
    Sep 25, 2009
    Fullerton, CA
    How about explaining it in "UP/Down" and "Right/Left" adjustments?
    The adjustments on the projector headlights I purchased are not working. I've got them set to acceptable positions, but there really is no movement when I use the adjusters.
  9. Pruittx2
    Pruittx2 OBD 1 Master
    675
    7
    May 6, 2008
    Lake Odessa, Mi
    Hope this helps,,,
    Here is how to adjust them with out paying,, or having an expensive unit to do so.
    Info from an ol' timer that worked a gm back in the day.
    With vehicle on level ground, measure from ground to center of headlamp. then measure the distance between the 2 lamps. Mark this measurement on the wall and back vehicle up 20ft from wall. on level surface. then aim lights to the marks. They WILL be spot on! :agreed:
  10. ak diesel driver
    11,475
    981
    Feb 7, 2009
    alaska
    perhaps this pic from the bottom will help. Middle adjuster adjusts the light vertically by pushing/pulling on the bottom of the light. The end one adjust the left left or right by pushing/pulling on the end of the light
Share This Page
