Links to info about Synthetic Oil
Discussion in 'Maintenance & Fuels' started by dtibbals, May 16, 2008.
  1. dtibbals
    dtibbals Official Gun Nut
    In an attempt to help build this site with resources for the users I have put together some helpful links about synthetic diesel engine oil. Hope you enjoy the reading!
    Mobil 1 Delvac
    http://www.mobildelvac.com/USA-English/Lubes/Product_Information/Engine_Oils___Diesel_Collection.asp
    Amsoil
    https://www.amsoil.com/storefront/acd.aspx
    Valvoline
    http://www.valvoline.com/pages/products/product_detail.asp?product=112
    http://www.valvoline.com/pages/products/product_detail.asp?product=113
    http://www.valvoline.com/pages/products/product_detail.asp?product=130
    Schaffer's
    http://www.schaefferoil.com/151_diesel_oil.html
    Chevron Delo
    http://www.chevrondelo.com/en/products/engineoil/default.asp
    http://news.moneycentral.msn.com/ticker/article.aspx?Feed=BW&Date=20080414&ID=8480647&Symbol=CVX
    Shell Rotella
    http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/product_rotellamulti.html
    http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/dir_tripleprotection.html
    http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/product_rotellasynth.html
    http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/product_rotellasingle.html
    Royal Purple
    http://www.royalpurple.com/motor-oil.html
    Pennzoil
    http://www.pennzoil.com/products/LongLife/index.html#HeavyDutyDiesel
    If I missed any please add them to the list! I hope everyone finds it helpful.
    David
    jrsavoie likes this.
  2. bighawg
    bighawg Proud Rider of the Short Bus
    3,380
    3
    May 9, 2008
    Carnesville, Georgia
  3. 03demax
    03demax New Member
    57
    1
    May 7, 2008
  4. dtibbals
    Wow my very first sticky!!!!!
  5. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    31
    May 4, 2008
    McHenry,IL
    Some really good info Dave. Hopefully will answer a few questions.
  6. WhtThndr3
    WhtThndr3 Yeah, I'm that guy
    Sweet, thanx for the info.:thumbsup:
  7. WilliamBos
    WilliamBos Serial Post Whore in the making...
    Red Line.
    http://www.redlineoil.com/products_motoroil.asp?productID=7&subCategoryID=1&categoryID=1
  8. RD400HP
    RD400HP Member
    199
    3
    Aug 26, 2010
    Fowler, Ohio
  9. snarl95
    snarl95 Active Member
    335
    185
    Feb 22, 2014
    Edenton,NC
    NOTE ON ABOVE-There is no API certification label that I can see.
  10. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    I read most of this report, and I'm conflicted with it. In my experience, anybody who has to pat themselves on there back this much and talk down about respected sites has an agenda behind it. Every section starts off with 3 paragraphs of him patting himself on the back about how great he is, and many had another paragraph or 2 about how much better he was than so and so. And several of his oil analisys results didn't even match up to the manufacturers posted contents. Particuliarly his test results of the revised 15w40 rotella, his results go dead against Shell's own press releases about the contents of it. There was a couple others I seen that didn't match up with the manufacturer either. And I've heard of bitog thtough several sources as well as some of the others that he made a point to say shouldn't be trusted.
    jrsavoie and WarWagon like this.
  11. WarWagon
    WarWagon Well it hits on 7 of 8...
    8,107
    2,439
    Nov 15, 2009
    AZ
    Pretty entertaining read (No seriously I really enjoyed it) and a lot of time wasted on 'talking down' his detractors. Where is my tin foil hat? Credit is due to looking at a single factor and only a single factor.
    One of the best rated oil by his single testing method Mobil 1 is exhibit A: Toasted camshaft. :facepalm: WTF, we ruined a camshaft (his standard of failure) following said site best of the best oil? Nevermind 1/4 million miles of towing scrapmetal loads well on the north side of sane in AZ (121 degrees F outside extreme temps) on grades that make a 1/4 drag strip racing look like a walk in the park. Nevermind the totally destroyed engine with cracked heads and cracked block. Perhaps the marketing also played a part in the carnage as Mobil 1 was supposed to be a once a year oil change, right?
    Looking at his own data and then discarding it... No matter how small of a difference the temperature that the oil can take matters esp. when you are at the limits of oil failure. It's an extra cushion you may never need until the moment you do. Not one single mention of piston scuffing that diesel engine owners experience when they have reached the limits of what their oil can take.
    Enough Oil Sludge problems are still around on modern gas engines including timing chain wear problems that caused GM to alter their oil life monitor. Oil Sludge due to the temperature limits of oil are well known. Just saying.
    Maybe I should send him a sample of tar, err, engine oil I have ruined. :D
    No. We should worry about something far more important than the oil and that's filters that can go the distance. Air filters to keep the dirt out and oil filters that actually perform better than a t-shirt stuffed into a can.
  12. THEFERMANATOR
    8,929
    2,222
    May 9, 2008
    ZEPHYRHILLS FL
    Lets just say his credentials and results have been call "questionable" by more than a few certified experts in the field. Did a search, and turns out he has been discredited more than a few times now. He actually reminds me a bit of old steaksauce.
    http://xtremerevolution.net/exposting-the-flaws-in-540rats-engineering-test-data-blog/
    http://xtremerevolution.net/exposing-the-flaws-in-540rats-rebuttal/
    http://speedtalk.com/forum/viewtopic.php?f=1&t=36916
    https://bobistheoilguy.com/forums/ubbthreads.php/topics/3966240/1?fref=gc
    And there is MANY MANY MORE postings out there discrediting his work.
    WarWagon and jrsavoie like this.
  13. btfarm
    btfarm 325,000 Worth Staff Member Moderator
    16,532
    2,208
    May 12, 2008
    Sandwich, Illinois
    Here's what Ol Smokey Yunick had to say about synthetic oil after he had used it a few times and saw the results... "I don't know what they charge for that stuff, but they ought to, at least, double it".
    As for this guy's blog... I couldn't get past his BS - I'm an engineer so you should worship my All encompassing knowledge... Well I had a career of pretty near the same credentials and I know quite a lot about the same things but unless you are an engineer in both automotive mechanical AND automotive chemical with years of hands on lab and real world experience, you are just giving your OPINION. So I didn't bother to read any farther...
    Bammer, WarWagon and Jaryd like this.
  14. jrsavoie
    jrsavoie Recruit
    5,569
    553
    May 8, 2008
    Rural Clifton, Illinois
    I skipped 99% and went to his ratings. Amsoil was up there, so I considered his findings good. LOL
Share This Page
