LBZ Glow Plug Replacement
Discussion in 'Maintenance & Fuels' started by saratoga, Mar 19, 2010.
  1. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,539
    63
    May 3, 2008
    Lithia, FL
    It started throwing P0676 out of the blue one morning which indicates that the glow plug on the #6 cyl is open. The last digit in the code indicates the cylinder number. I know you're supposed to replace all 8, but at $20 a piece, I'm going to chance replacing only the bad one.
    [​IMG]
    On the Dmax, the cylinders are numbered starting from the passenger front 1-3-5-7 and the driver's front 2-4-6-8. The number 6 cylinder is the third one from the front on the driver's side.
    First, disconnect the batteries.
    Remove the inner fender liner which is the biggest PITA of the whole process. I didn't show pics of that because it's not hard to figure out, just that there are about 10 clips holding it in and it's got a couple of big harnesses clipped to it from inside also. You can get a good view of all 4 glow plugs this way- they're right on top of the exhaust manifold and slightly angled towards the back of the engine. There will be one wire with an 8 mm nut holding it on.
    [​IMG]
    Next, remove the 8 mm nut from the offending glow plug.
    [​IMG]
    [​IMG]
    Next, using a 12 mm deep well socket, carefully remove the glow plug. I'm not in the salt belt so corrosion isn't an issue here, but I imagine these things could get pretty nasty over time... penetrating oil is probably a good idea.
    New and old. The tip isn't broken off the old one THANK GOD! :hurray:
    [​IMG]
    They're supposed to have 1 ohm or less resistance; this one might be a little over. :eek:
    [​IMG]
    I put some anti-sieze on the threads and started the new glow plug in the head by hand making sure not to cross the threads. Tighten to 18 ft/lb. Reinstall the connector and put the 8 mm nut back on the connector.
    [​IMG]
    Put the fender liner back in, clear the codes and you're done.
  2. btfarm
    btfarm 300,000 Worth Staff Member Moderator
    16,150
    1,473
    May 12, 2008
    Sandwich, Illinois
    Nicely done Grady!
  3. CtChevy427
    CtChevy427 Still Kicking.... Staff Member Lead Moderator
    6,152
    117
    Apr 14, 2008
    North Haven, CT
    Nice DIY Grady. You should be fine with only replacing one.
  4. LtEng5
    LtEng5 Member
    228
    0
    Oct 10, 2008
    CT
    Thanx for the write up ....#8 will be next on my to due list as of tonight....maybe I'll get to it before October.....
  5. dentpusha
    dentpusha LOCKED&LOADED
    881
    0
    May 9, 2008
    a-town texas
    Well my truck started throwing a 0678 code this week(twice so far).Im glad to see that the number 8 is on the driver side b/c the twins are deff going to make the pass side a pita to change.Whats the main reason for changing all 8?I only have 47k but I DO NOT want to remove the twins to replace glow plugs that are working.Thanks for taking the time on the write up.
  6. RayMich
    RayMich Active Member
    4,717
    7
    May 9, 2008
    Mid Michigan
    Very nice write-up Grady!
    Looks like I'm gonna be replacing #7 glowplug on my '06 LBZ this weekend.
    I'm hoping the tip is not broken off....
    The Tech Bulletin says to replace all 8, but I'm hoping I will only need to replace the one that's setting the P0677 code.
    What is the risk if I only replace ONE glowplug?
  7. saratoga
    4,539
    63
    May 3, 2008
    Lithia, FL
    I replaced that one on my truck and never had any problems out of the others.
  8. RI Chevy Silveradoman
    RI Chevy Silveradoman At your service Staff Member Moderator
    9,857
    569
    May 3, 2008
    Rhode Island
    P0675 DTC Glow Plug Replacement (Number 5 Cylinder)
    Just to update the record. I had the P0675 DTC come up. Thanks to Grady, the job was a snap. $25.10 for the part at the dealer. The fender liner removal was the hardest part of the job. (PS. clean out the gunk that is built up behind the fender liner while it is off.)
    Photos right to left, top to bottom.
    Photo 1 The tip still on the bad glow plug. (Oh what a relief it is!) And the new one.
    Photo 2 The overall photo with the fender liner dropped.
    Photo 3 The glow plug removed with the wire hanging.
    Photo 4 Another overall photo. It was a little tight due to my larger fuel filter hanging down a little lower. Still no problem.
    Photo 5 A photo of the front of the motor. Cylinders 1 and 3.
    Photo 6 Close up view of the glow plug removed.
  9. kramer56
    kramer56 Recruit
    103
    0
    May 7, 2008
    Carthage,NY
    What do you have to get out of the way besides the fender well insert to get the #6 glow plug? them pics looked a little tight lol.
  10. RI Chevy Silveradoman
    9,857
    569
    May 3, 2008
    Rhode Island
    Nah. Plenty of room with just the fender liner removed. It is a piece of cake! Easy.
  11. kramer56
    kramer56 Recruit
    103
    0
    May 7, 2008
    Carthage,NY
    ok here in NY they seem to put more salt on the roads than the ocean will ever have, what are your ways to help it from breaking when take it out?
  12. CtChevy427
    6,152
    117
    Apr 14, 2008
    North Haven, CT
    I would start hitting it with a good penetrating oil days before you plan on removing it. I have read that Acetone and power steering fluid do well together when mixed 50/50.
  13. btfarm
    16,150
    1,473
    May 12, 2008
    Sandwich, Illinois
  14. RI Chevy Silveradoman
    9,857
    569
    May 3, 2008
    Rhode Island
    To be straight up, the glow plug came out very easily. The threads and size of the "bolt" if you will was small. Even if it were seized up, one could break it loose without much effort. I did not spray mine, and I live in the Northeast also. It came out like butter.
  15. Bammer
    Bammer Member
    338
    0
    Jul 23, 2008
    SW CT
    Thanks to all the powers that be that #3 came out easily and whole last night! :thumbsup:
    Thanks to Grady for the write up and pictures. :hello:
  16. RI Chevy Silveradoman
    9,857
    569
    May 3, 2008
    Rhode Island
  17. btfarm
    16,150
    1,473
    May 12, 2008
    Sandwich, Illinois
  18. Bammer
    Bammer Member
    338
    0
    Jul 23, 2008
    SW CT
    I was real nervous as I was sliding that old one out I tell ya !
  19. RI Chevy Silveradoman
    9,857
    569
    May 3, 2008
    Rhode Island
    I hear you. Once you see the entire glow plug come out, it is like you just won the lottery. :)
  20. btfarm
    16,150
    1,473
    May 12, 2008
    Sandwich, Illinois
    It appeared to me when I took it out that that thing would have to really swell alot to not want to come out. I was all ready to put the shop vac to it and say a prayer that I got all the chunks if I had to. :D
Share This Page
