lbz exhaust
Discussion in 'Intakes and Exhausts' started by Cheyenne19, May 15, 2008.
  1. Cheyenne19
    Cheyenne19 Special agent C19 A(ACLU)
    540
    0
    May 4, 2008
    The Delta
    What's the best exhaust to use and maintain a stock sound in the cab. I've run a straight pipe for a while, but I'm not sure I want all that noise on another truck.
  2. alli_gator
    alli_gator Recruit
    101
    0
    May 9, 2008
    Las Vegas
    I have had good luck with Magnaflow exhaust not being to loud in the cab. I run it and it's not loud in the cab at all.
  3. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    I have 5" mbrp no cat/muffler and its not that loud under normal use, if you get on it, it'll wake up the dead :cornut:
    i may get a 6" tip, but i have to lift the truck first. its already hit the curb once:frown2:. 5" is pretty big.
  4. GmcLbz
    GmcLbz New Member
    285
    0
    May 3, 2008
    Mcdonough, NY
    I have run a 4" Mbrp downpipe back w/muffler for about a year and a half now. It is fairly quiet until you get into it and even then it's not bad.
  5. RedneckBuckeye
    RedneckBuckeye Recruit
    837
    0
    May 3, 2008
    Indiana
    It is loud straight piped, but I love it
  6. TIM Z
    TIM Z Tie Rod Bender
    294
    0
    May 7, 2008
    Navarre, Ohio
    x2 :yesnod:
  7. Mad Maxx
    Mad Maxx See, what had happened was... Staff Member Moderator
    5,995
    118
    May 3, 2008
    Long Island, NY
    Corsa all the wayyyyy!!!
  8. Unit453
    Unit453 Cruises comfortably at 140... Staff Member Administrator
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
    I like my cat back. My 04 LLY was a 4" turbo back with no cat and it sounded awesome. But now, I dont like the LBZ hiss at throttle so I opted to leave the cat on.
  9. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    Get rid of your Cat and put the Diamond Eye Direct Pipe on and it REALLY tames down the LBZ hiss, makes it more of a rumble.
  10. Unit453
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
    Well, winter up here has destroyed my system. Its all caked in rust.
    I'll end up with a completely different system once I move and get settled. I kinda like the Silverline style tips and I think I'm gonna go with duals this time. I'd like to keep my MBRP muffler because there wont be anything wrong with it.
    Get a sound clip of that with the downpipe. I'd like to hear it.
  11. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
  12. Unit453
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
  13. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    I have a place I go to, but even before I took the Cat off, I asked if it would be a problem, and they said since I DON'T have Commercial Plates, it's just a safety inspection for a Diesel.
    But I think Long Island and "Upstate" has different "rules" for inspection, because my sister works in the Capital, so she had to move up there, but her inspection was from down here on the Island, and when it came time for her to get it inspected, the place that did her truck up there said the Inspection wouldn't be valid here on the Island, and she "could" get a ticket. But I don't see how that is possible.
  14. Unit453
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
    I think thats retarded.
    So, I'll end up taking the cat off here eventually...
  15. Cheyenne19
    540
    0
    May 4, 2008
    The Delta
    Has anyone used the mbrp resonator?
  16. jrkrace
    jrkrace Recruit
    550
    0
    May 9, 2008
    Connecticut
    I was leaning towards a Corsa system until I stumbled on a Banks Monster for a pretty good deal. 1 year later and the system is still perfect.
  17. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    28
    May 4, 2008
    McHenry,IL
    I have the same set up on mine; 5" MBRP no cat w/ muffler. There is virtually no drone in the cab. From the inside, sounds a little throatier then the stock set up does, but like BigDog said, from the outside, a real nice tone from the outside, and if you need to romp on it, people will hear you. I'm very happy with what I decided to get compared to the cat back set up.
  18. alli_gator
    alli_gator Recruit
    101
    0
    May 9, 2008
    Las Vegas
    They are a small muffler, nothing fancy, but they do cut a little sound.
  19. 12ga diesel
    1,766
    28
    May 4, 2008
    McHenry,IL
    jrkrace, how is the drone in cab with the Banks system? I was looking at the Banks but a friend of mine that had it on his Cummins wasn't happy with it. A lot of drone. Plus I really wanted a 5" system, and Banks only does a 4". But another guy with a Cummins I know said the MBRP gave him a lot of drone as well, so I guess it just might be different from set up to set up.
  20. Cheyenne19
    540
    0
    May 4, 2008
    The Delta
    The drone is what I'm trying to avoid.
Share This Page
