LB7 injectors
Discussion in '01-04 LB7' started by David MF Tibbitts, Jan 26, 2016.
  1. David MF Tibbitts
    David MF Tibbitts New Member
    3
    0
    Jan 26, 2016
    maricopa az
    I am going to replace my injectors and I was thinking about using
    Bosch Stock Fuel Injectors for 2001-2004 LB7 Duramax
    IIS0986435502P from Thoroughbred diesel
    Any opinions on these???? And or A better option.
  2. THEFERMANATOR
    8,978
    2,302
    May 9, 2008
    ZEPHYRHILLS FL
    I reccomend lincoln diesel. $1699 +$800 core charge. Your link is $2040 +$1200 core charge. They sell top notch OEM remans, and have made a great reputation for themselves. The next time mine is due, I'm going to go with EXERGY BOSCH MOTORSPORTS 30% over SAC nozzles. The VCO nozzle design was only used on the LB7, and has proven to be alot of the LB7 injector issue. The BOSCH motorsport nozzles use an SAC design like LLY+ used.
    tanman_2006 likes this.
Share This Page
