LB7 FAQ's
Diesel Dually
awaiting your return...signed... your friends
Likes
0
Mile High
Thread starter #1
Lets start a FAQ section here.
Post up the questions, answers TSBs and I will consolidate them all into one FAQ Post...with credit due to the original poster.
ZF6 MAN
The Unwritten rule
Likes
0
#2
Fuel Injection
Q: What are the symptoms of fuel injectors failing?
A: Poor fuel economy, excessive smoke and smell at idle, rough idling, engine oil contaminated with Diesel fuel, hard starting, excessive fuel return rates, reduced engine power, illumination of check engine light
Q: I think my fuel injectors are failing are they covered by warranty?
A: All 2001-2004 LB7 code duramax diesels are covered by warranty for 7 years of original service or 200,000 miles whichever comes first.
Q: Can I buy aftermarket injectors so I wont suffer injector failure?
A: No, Bosch makes all of the injectors for these engines however there are aftermarket nozzles (tips) that can allow for more fuel flow.
Smokin LB7
Just Takin' it From a Dig
Likes
0
Greeley, CO
#3
Q. Is the LB7 diesel motor the best Diesel every made?
A. HELL YA!!!!
Q. What kind of power can a stock LB7 motor hold reliably as a daily driver?
A. Generally most have found that 500RWHP is a fairly safe reliable number, BUT EVERY MOTOR IS DIFFERENT.
Q. What years do the LB7's come in?
A. 2001-2004.5
Q. In this time of outrageous fuel prices and a tough time keeping the tank full, what can I do to get a little more mileage out of my LB7?
A. Exhaust and intake have shown to help minimally, however it seems as though tuning is where people are making the most gain. Every engine and programer are all different and show different results
Smokin LB7
Likes
0
Greeley, CO
#7
A. HELL YA!!!!
A. 2001-2004
ON EDIT
richard cheese
the MAIN muff hugga
Likes
0
#9
Q: how can I increase my boost pressure in my LB7?
A: PPE boost valve/ PPE/Kennedy boost control.....or anything that restricts the flow of pressure from the turbo to the wastegate
jcool
#78 A(ACLU) FNG
Likes
0
Richlands, NC
#12
exhaust and a lowpower programmer(stock tranny safe) and a light right foot keeping speeds around 60-65 on the highway seems to be the best mileage I have seen
Likes
0
MI
#14
Q: I hear what sounds to be air blowing with the engine running, poor power, kinda sluggish, my boost gauge is reading low whats the deal?
A: Look at the intercooler tube on the Drivers side for a small hole where it is rubbing on the power steering line. Weld, Epoxy or other patch, protect repair with hose or adjust clamps to take up slack, should be good to go.
WanaDmxSub
Recruit W/gray hair
Likes
0
#15
You can have good balance rates and bad injectors.
Bad balance rates will not get your injectors replaced under the special policy...but it does happen.
Yes, you can remove the Cat with out setting a code.
Plugging the EGR will set a code.
Yes, there are LB7's with Cat's and EGR's!
Heartbeat Hauler
A(ACLU) Agent Yoda
Likes
1
Morgantown, WV
#20
A. HELL YA!!!!
A. 2001-2004.5
A. HELL YA!!!!
A. 2001-2004
ON EDIT
Actually 2001 - 2004.5 is correct for the LB7 run, the LLY showed up mid-year '04
