Kennedy fuel guage
Discussion in 'GM Duramax Engines' started by JD4440, May 5, 2008.
  1. JD4440
    JD4440 EFILive impaired.
    49
    0
    May 3, 2008
    Does any of you have on of Kennedy's fuel pressure guages you plug into the test port on front of the engine? I would really appreciate if someone had one I could borrow :eek:13:
  2. Turbine Doc
    Turbine Doc Just Another Diesel Guy
    What's special about it, Grainger or McMaster Carr or any other industrial supply house has gauges many types/ranges for not a lot of $$$
  3. JD4440
    49
    0
    May 3, 2008
    All I know is it is like a hyd coupling. all the parts houses guages screwed on.
  4. modified
    modified modified
    27
    0
    May 16, 2008
    NE Wisconsin
    I got one.
    30" Hg to 15 PSI which works with lift punps.
    I installed about 5 feet of plastic hose to it so you can tyrap it under the windshield wiper and monitor your fuel pressure while driving.
    Send me a PM.
  5. sdaver
    sdaver New Member
    8
    0
    May 11, 2008
    the frieght is half the cost..........bite the bullet
  6. sparky1562
    sparky1562 Just a hack
    17
    0
    May 11, 2008
    Middle TN
    I have one if you want to drive down to Music City one day!
  7. JD4440
    49
    0
    May 3, 2008
    Fixed the problem I believe. Thank you guys for your offers.
Share This Page
