John Deere 410 loader backhoe engine torque specs
Discussion in 'Tractors & Farming' started by 3500GMC, Jun 21, 2013.
  1. 3500GMC
    3500GMC What T F, over
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    It's a older '78 2WD extendable backhoe. Nice old machine. 4 cyl diesel, shuttle shift, 1 yd bucket etc..
    Fell victim to electrolysis in the liners, engine took on some coolant but was shut down quickly upon loss of coolant.
    We are re-assembling with new liners, rod bearings, rings, lifters and associated seals/gaskets,
    So... need pointed to an online source for torque values, valve adjustment sequence things of this nature, or , if anybody has a book or personal experience.. Any and all info would be appreciated!
  2. ak diesel driver
    ak diesel driver 6.5 driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    we have an 1980 JD450 maybe it has the same engine?
  3. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Les, probably.. The 219ci four. Pretty common JD diesel engine.
  4. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    Ill see if I can find the book for it and copy any specs
  5. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Today the bottom end went together. Torqued the rods to 60lb.ft. Liners and orings went in smoothly. New tappets were a lube and drop in deal. Need to be sure of the torque and sequence before we button up the head, top end.
  6. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    OK OK I'll try to remember. maybe tomorrow afternoon I'll have some time.
  7. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
  8. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    A few pics.
    Huge crank and rods in this thing. Learning more, they call this the 300 series JD diesel engine.
  9. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    how's this?
  10. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Excellent. Do appreciate it sir. Couple questions..
    Did your manual make any mention of retorque?
    Any mention of '300 series'? There are 400 series diesels but I'm not sure which one would be in your 450.. Don't wanna get crossed up on torque numbers.
  11. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    engine serial # is m53tf with the 5 being the series. I don't know if that helps or not.
  12. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Ok looks good. Once again, much appreciated Les.
  13. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Need the next page for running the valves if you could.. Looks like the next page after the one pictured in post 11.
    The lash settings I found were .014int & .018ex. Getting close to lighting a fire in the ol beast.
  14. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    here ya go
  15. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Sweet! Thanks for helping a brother out.
    We have a JD parts manual (buncha numbers) for these if you ever need anything, just look me up.
    Never got around to looking up a shop manual.. (obviously :eek:)
  16. ak diesel driver
    12,758
    2,762
    Feb 7, 2009
    alaska
    Thanks but we have a parts book too
  17. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    The JD410 rides again. (digs again) whirled over and hit off on all 4, purged the air bubble from the fuel and stalled, cranked a few more revs and took right off. Did a video but haven't uploaded it.
    Next on the list is a good cooling system flush/rad cleaning.
  18. Shane Wisecup
    Shane Wisecup New Member
    1
    0
    Apr 8, 2017
    Hudson
    Do these torque settings apply to a JD 410 backhoe.
  19. 3500GMC
    5,463
    590
    Jun 7, 2009
    Nashport, Ohio
    Worked good on the 410 engine we did an inframe on. Almost 4 years ago and going strong.
  20. bluklewis
    bluklewis New Member
    10
    6
    Aug 15, 2017
    Santa Cruz CA
    That's impressive.
Share This Page
