JD 420 snow plow mount rebuild
Discussion in 'Tractors & Farming' started by razur65, Feb 15, 2018.
  1. razur65
    razur65 Member
    22
    51
    Dec 5, 2017
    Central NY
    So my neighbor brings his JD 420 up to the barn for some "weld the blade back on" work.
    I welded the blade rails on back in the summer when he was trying to use it as a bull dozer and it failed. I told him it was prolly only goodfor snow pushing and he agreed. But, he still used it for a dozer. And it broke again, so now its maybe time to push some snow so needs it fixed again.
    The blade was originally "welded" in the center and on the side angles directly to the back of the blade, "supported" by a single pin (bolt) by the gob ob scrap steel at the bottom center of the lift angle.
    Jaryd likes this.
  2. razur65
    razur65 Member
    22
    51
    Dec 5, 2017
    Central NY
    I cut off all the bad "welds" and figured out a way to mount the blade to the lift angles that would allow for some flex and give in the lift action so the blade wouldn't be forced to be rigid in it's work.
    Made these angle plates to support the existing 3-pt bar at the bottom of the old plow frame. Bushings are cut in half and welded into bottom bracket and a top plate that completes the bracket assembly.
    Will L. and Jaryd like this.
  3. razur65
    razur65 Member
    22
    51
    Dec 5, 2017
    Central NY
    I was always taught if you can make "out of position" welding to in position weld to do it, so sometimes it gets a little weird but the welds are the best!
    Re-attached new fabricated mount to existing angle steel, new chains, lifts nicely and now "floats" with terrain instead of being completely rigid and stressing the frame and welds.
    So now this is done, on to fixing the wife's truck!
    Will L., BIGR, Jaryd and 2 others like this.
  4. btfarm
    btfarm 330,000 Worth and counting Staff Member Moderator
    16,578
    2,331
    May 12, 2008
    Sandwich, Illinois
    Looks like a solid repair.
    razur65 likes this.
  5. NVW
    NVW Well-Known Member
    8,691
    1,293
    May 5, 2008
    Castor, AB.
    Nice job. While it is nice to weld on the flat, if you make yourself weld in all positions you will really improve. Makes it nice when there is no way you can position the part.
    razur65, btfarm and Jaryd like this.
  6. jrsavoie
    jrsavoie Recruit
    5,577
    564
    May 8, 2008
    Rural Clifton, Illinois
    My biggest issue with out of position anymore is being able to see. I can never get my head in the right position with the tri-focals.
    I do have one pair of cheaters that used to work. Bout time for another eye exam
    razur65, NVW and btfarm like this.
  7. btfarm
    16,578
    2,331
    May 12, 2008
    Sandwich, Illinois
    I think the longer you farm with old equipment, the better you get at all position welding.
    razur65, NVW, jrsavoie and 1 other person like this.
  8. Will L.
    Will L. Well-Known Member
    7,406
    6,008
    Jan 25, 2013
    Boulder City Nv
    Every pro welder I worked with that needed glasses had a “cheater lens” in his hood. Got in couple le situations where they had me dona weld for them and hand me their hood. Most magnify slightly so I could use it buy it was like using a magnifying glass. A couple others were so strong I couldn’t see at all through them and had to go grab my hood.
    I imagine the lens are a little pricey, but something they all said was how much it helped them. Something else a few of them said was they used to get headaches after an hour or so of welding and the lens stopped it. Might be worth checkin out.
    For everyone that wnats better conrol in their welds, welding is all about practice. Learn the basic pattern techniques and then do it a thousand times. Unfortunately I have learned it is something that if you go long enough without practice, the motor skill fades.
    One ole guy that was a great welder had been out of work for 11 years, in prison. He realized he would loose the fine repetition motor control, so he drew artwork for hours every day using the various weld control patterns and rigged a “stinger” out of toilet paper rolls to hold the pencil so it felt like welding. Said he made it so the pencil would slowly slide as he went so it was like the rod burning up. Actually taght himself to weld both hands in prison on papaer. Guys welds looked like a machine by the end of the first day on the job.
    After seeing me do some great repairs on others mistake areas and do some really bad ones from being out of practice, He told me to just draw raw patterns while watching tv and I would improve my “automatic repetition”, I just can’t care enough to become as good as I once was to do it to say if it really helps personally or not, but makes sense. If anyone does try it, save your first page, and compare it to your tenth.
    razur65, jrsavoie and NVW like this.
  9. BIGR
    BIGR Lucky To Be Here
    5,273
    2,768
    Jun 9, 2008
    Appalachian Mountains
    Very nice, that should get the job done.
    razur65 likes this.
  10. Will L.
    7,406
    6,008
    Jan 25, 2013
    Boulder City Nv
    I always wondered if a snow plow could be used as a mini dozer btw (says the guy in the rock and caliche filled desert).
    razur65 and jrsavoie like this.
  11. razur65
    razur65 Member
    22
    51
    Dec 5, 2017
    Central NY
    Yup, I use trifocals everywhere except in the shop, got a couple pair cheap cheaters that take the abuse!
  12. NVW
    8,691
    1,293
    May 5, 2008
    Castor, AB.
    I use a 1 1/2 lens in the helmet, if I'm really close up I throw on a pair of cheater glasses. I'm far sighted.
    jrsavoie likes this.
Share This Page
