Iron Bull Bumpers
Discussion in 'Exterior' started by bighawg, May 15, 2008.
  1. bighawg
    bighawg Proud Rider of the Short Bus
    3,380
    3
    May 9, 2008
    Carnesville, Georgia
    Bill I was checkin out your website, great lookin' stuff. I have a 12000# ramsey winch, can I use this winch in one of your winch bumpers?
  2. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    you certainly can....You can fit up to a warn 16.5Ti in any of my fullsize bumpers
  3. Pepperidge
    Pepperidge Member Advocate Staff Member Lead Moderator
    12,367
    364
    Feb 10, 2008
    Slidell, La
    for a non lifted truck...do they have more or less ground clearance...and how much front end sag should someone expect from the added weight...
    I have an 01' could I put an 03' up grill on and use this? not sure if/what I would need to do this ...other than the grill obviously....
  4. Pepperidge
    12,367
    364
    Feb 10, 2008
    Slidell, La
    Billy...any answers to this?
  5. MattZ71
    MattZ71 Tennessee Diesel's Mod
    355
    0
    May 16, 2008
    KY/TN line
    also bill, do i could see, but do you all have any bumbers to fit a 97' full size z71 rear bumper?
  6. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    sorry...i've been out and about...I have no clue what the frame in the 99-02 looks like so I can't tell you if it will work pep and matt, I am designing those bumpers right now...
    However pep, Its your call if you want to do it and modify the mounts and/or frame to work..I'll send the mounts raw and you can coat them when you are done....I did it for one guy and never heard how much work it was
  7. Pepperidge
    12,367
    364
    Feb 10, 2008
    Slidell, La
    TJ (the killing road) said i should just put on a 03 1500grill ...I don't know about that...
    I really want the 03-06 HD grill...do you know if just putting a 03-06 hd GMC iron bull will just mount right up...and all I would have to do would be to change the grill?
    ask some of your fab guys/designers what they think... and what about clearance and front end sag ???'s I asked...
  8. MGlickLBZ
    MGlickLBZ Agent Quack Smacker
    234
    0
    May 5, 2008
    South Central, WI
    Call me crazy, didn't the 01-02s have a differnt hood than the 03-06s? The 01-02s had a rounded downturn to the grille while the 03-06s is more of a 45 degree angle.
  9. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    Thanks bill!! keep me updated on the rear bumpers! oh, and if ya need a test truck, i here!!
  10. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I know the frame horns changes on the 99-02 chevy to the 03-07 chevy...the mounts and the bumper had to be changed drastically....
    but like I stated, I know that my mounts can be modified as its been done in the pasts especially on the fords when people with the 99-04 do the 05-07 conversion....
    as for the droop of the front end...the bumper without a grille guard is about 160-180 lbs before winch...There is less than 1/4 sag from the weight of the bumper with winch and lights... so you should have no issues
    PM for a price quote Pep if you are interested
  11. Pepperidge
    12,367
    364
    Feb 10, 2008
    Slidell, La
    I'm trying to work out the 03 up grill and what else I will need to do...
  12. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    Sounds good...let me know...mods get a "special price" lol $500 over retail...lol just kidding pep...I made Steve a good deal...I'll do the same for you
  13. Pepperidge
    12,367
    364
    Feb 10, 2008
    Slidell, La
    same hood and fenders...just a differrent bumper and grill and that in between spacer... not sure if the frame horns dunes speaks of being changed apply to the HD's...I hear conflicting reports :crazy:
  14. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    For the record, I said that the 99-02 chubby had different frame horns...I said I didn't know about the jimmy...the mounts may work, they may need a little massaging, they may need to be reworked all together...I have no clue...
    I do however have a guy here locally that is dead set on my bumpers with a 2000 GMC 3500....When I actually have a week to mess with it, I will get it done once and for all
  15. Pepperidge
    12,367
    364
    Feb 10, 2008
    Slidell, La
    2000 3500 is old "classic" body style...
    2001 started the new HD frames and body style for Chevy's and GMC's... 99 on the 1500 trucks
  16. 01duramax6spd
    01duramax6spd Recruit
    187
    0
    May 6, 2008
    You can put a 99-02 1500 grille in a 01-02 HD so it doesn't drop down and you can have a strait top on your bumper. I've seen that before. As far as an 03 grille in an 01 it won't happen if you have a Chevy. GMC maybe. I'd have to look at mine.
    Edit,I see you have a GMC si it may work. I had to get a new grille for my GMC and it was like $225.
  17. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    hey bill any updated for rear-bumpers for te 88-98 full size chevy/gmc's??-I need one!
  18. DunesRunner08
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    Designing isn't an over nite thing Matt...Design stage usually takes about 2 months of us drawing and brain storming...then we mock it up on the truck which takes about 2 weeks, and then we have to program the design into the computer to cut it and then we have to make sure its perfect and then make a real one and test fit it...and so on and so forth....I wish it was an overnite ordeal, I'd have bumpers for anything that moved.....lol I'll keep you informed though
Share This Page
