  2. Texas and Louisiana needs your help!
    We have members affected with this storm.
    Update: Crowdfunding Link by JJ Watt of the Houston Texans: Go Here
    Dismiss Notice
intermittent starter grinding
Discussion in '01-04 LB7' started by devildogadam, Nov 29, 2016.
  1. devildogadam
    devildogadam Active Member
    278
    80
    Sep 2, 2013
    Yakima WA
    I have heard starter grinding on the flywheel is a common problem on the lb7 engines. Is there a fix. Normally will not do it unless I try to start right away. If I wait until it goes though the whole driver 1 set up she starts right up. Anyone else have this issue?
Share This Page
