injector balance rates
Discussion in '01-04 LB7' started by richard cheese, May 20, 2008.
  1. richard cheese
    richard cheese the MAIN muff hugga
    345
    0
    May 7, 2008
    WanaDmxSub pm'd me and told me how to check the injector balance rates...
    i had a 2......a a couple 3's , a couple 4's , a couple .8's and a 1
    are those bad enough to start looking at replacement??
  2. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    not really. you need to check the return rates and pressure to be definate. especially under warranty. gm is real stickler on the paper work for these.
  3. whitetrash21
    whitetrash21 Put on the damn helmet day........
    788
    0
    Apr 29, 2008
    Vegas
    that in park or drive....???
    park, the 4's are pushin it. drive, everything would be fine then. like stacks said, dealer will wanna go beyond that to ensure that injectors are failing.
  4. SfcJones
    SfcJones A(ACLU) SGT. SLAUGHTER
    3,504
    12
    May 3, 2008
    South Ga.
    I would agree the the 4's are pushing it, but you would still have to check them drive too and the return rates, but if you have white smoke at idle...more and likely you have a injector failure.
  5. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    yeah. the white smoke is a pretty good indicator.
  6. Zstarkey
    Zstarkey Recruit
    16
    0
    May 9, 2008
    Ok guys i would like to check my rates but dont know how. I have a bully dog PMT, intake and exhaust and im afraid that the stealer will void my warranty. Any ideas
  7. whitetrash21
    788
    0
    Apr 29, 2008
    Vegas
    pull the bully dog out. i've been to the dealer several times with mine and they dont say anything about the mods. just make sure it isn't a "power up" device so they wont give you grief about it. they most likely will charge you a ~$90 fee to check br though.....
  8. WanaDmxSub
    WanaDmxSub Recruit W/gray hair
    89
    0
    May 8, 2008
    Don't let the dealer charge you for more than 30mins of time, $40-$50.
    Or
    Let us know about where you are and maybe someone close will do it for you?
  9. Zstarkey
    Zstarkey Recruit
    16
    0
    May 9, 2008
    is there any other way of checking balance rates because i have the pmt with the a-pillar mount so its not that easy to just take it out.
  10. whitetrash21
    788
    0
    Apr 29, 2008
    Vegas
    if you know someone with efilive, ppe, or a tech 2.... they can check it for you.
  11. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    my truck had some blue smoke idleing this afternoon, and it wasn't a very smooth idle, very rough. i think i'm gonna have to take it in, damn injectors...
Share This Page
