How to remove the front drive shaft from a NP 246 transfer case.
Discussion in 'GM 6.5 Diesel Engines' started by jrsavoie, Aug 17, 2010.
  1. jrsavoie
    jrsavoie Recruit
    5,369
    374
    May 8, 2008
    Rural Clifton, Illinois
    Do you cut the clamps on the rubber boot and slide it apart?
    Does anynody have any pics &/or instructions for removing the front drive shaft from the NP 246?
  2. Jess_sr
    Jess_sr New Member
    61
    0
    Oct 7, 2009
    Toms River NJ
    Cut the clamp then use a wire tie to replace it after you reassemble it.
  3. jrsavoie
    jrsavoie Recruit
    5,369
    374
    May 8, 2008
    The clamp closest to the transfer case?
  4. bk95td
    bk95td 6.5 nut job/addict
    2,548
    9
    Nov 26, 2008
    Any I've seen, you take the 4 bolts out of the flange on the transfer case and the 4 bolts out of the yoke on the front differential.Compress the shaft by prying it out of the front diff. No need to take the shaft apart.
  5. jrsavoie
    jrsavoie Recruit
    5,369
    374
    May 8, 2008
    This must be a 1998 and newer thing or 246 transfer case specific. no bolted flange from the transfer case. All the other transfer cases I had were as you described.
    My newest service book is a 1996 so it didn't show anything applicable.
    Why do they take something that works and change it?
  6. bison
    bison Well-Known Member
    the setup is basicly the same as far as i know,the 98 could be the same on both ends(no flange)
  7. Jess_sr
    Jess_sr New Member
    61
    0
    Oct 7, 2009
    Toms River NJ
    Doesn't matter. Your choice.:)
Share This Page
