How to bleed an 01 cummins.
Discussion in 'All Other Diesels' started by ak diesel driver, Nov 11, 2015.
  1. ak diesel driver
    ak diesel driver 6.5 driver
    12,342
    2,042
    Feb 7, 2009
    alaska
    My brother ran his 01 out of fuel and now can't get it to start. What's the bleeding procedure?
  2. NVW
    NVW Well-Known Member
    8,461
    843
    May 5, 2008
    Castor, AB.
    I don't have any experience with this engine, on all the diesels I own I crack the line feeding the IP, some IP's have a bleed screw on them, then crack all the injector lines. The Cummins shouldn't be any different.
  3. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    On an 01 i believe you start by opening the fuel filter lid slightly, bump the key to start it, and let the lift pump run to get fuel up to the filter. Once you get good fuel out the filter, close it back up, and I always cracked open the front 3 lines(they weren't as hard to get to as the rear 3), and spin it over until you get good solid fuel streams or it tries to fire. Once it does try to fire or gets good fuel out them, close them back up, and turn it over until it fires up.
  4. ak diesel driver
    12,342
    2,042
    Feb 7, 2009
    alaska
    so after we got it running it quit again. no fuel from LP. His sending unit needed to be replaced so we figured it was a good time to do the in tank LP conversion. Got the kit and got it installed and still no fuel. Diving into it a little deeper I discovered he wasn't getting any power to the LP. Turns out power comes from the ECM. So for a work around I found a fuse that was hot in only the run position and added a tap to signal the relay. ended up also having to remove the ground and ground it somewhere else. So now for a couple of ?s Had 2 codes 1689 and 1688 IIRC. said something about auxillary inputs. So I cleared the codes but I'm wondering if they'll come back because of the disconnected LP wires.
    Next ? is IIRC the pump pressure is supposed to be fairly low, any possibility of an in tank conversion for a 6.5?
  5. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    The fuel system in that truck uses a regulator built into the banjo bolt for the return line from the injection pump to maintain 14-15 psi. And are you sure on the codes? P1688 is an injection pump death code(internal fault inside injection pump), and P1689 is a loss of communications between the ECM and VP44 injection pump. Since you already have an ECM issue, it could be your problem. I read where others have found the P1y89 to be a wiring problem in the injection pump plug, and others have found it to be a poor ground to the PDC.
  6. ak diesel driver
    12,342
    2,042
    Feb 7, 2009
    alaska
    PDC?
    It's running fine for now
  7. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    Power distribution center(underhood fuse box).
  8. 1994ch
    1994ch Active Member
    427
    197
    Dec 6, 2008
    South Carolina
    Did this issue ever come back? I just got a P1689 on an 01.
Share This Page
