honda rancher wont crank
Discussion in 'General Recreation' started by farmer0_1, May 22, 2008.
  1. farmer0_1
    farmer0_1 stuck in the past
    58
    0
    May 11, 2008
    cornelius, oregon
    just like she says my brother bought a honda atv rancher three years ago and it won't crank for him . this thing is 200 miles away and he is no mech . anyway says battery is clean and charged up and has never had an issue with it . says he hears a solinoid behind the batter clicking alot. anyway don't have much to go on. it has the electric shift. told him i would lone him his old three wheeler i bought off him as it runs and runs . he told me where i could ride it nicely. told him its most likely a safety switch issue just got to go looking with a test lite.
  2. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    Have him run the gears and then try it again.. There was a recall on the 02 and 03 ranchers for this issue. My wifes would do it every so offten. I could clear it by shifting up and down, took it in and had the recall done, been great since.
  3. blksmok
    blksmok Don't listen to me.
    81
    0
    May 3, 2008
    Mesa, Az
    Can he start it with the pull cord?
    The obvious stuff is good right? key on, bike in nuetral, kill switch on handle bar in the middle (or "on") position? I'd pop that little piece of plastic on the side off and try and pull start it with the pull cord.
  4. 01duramax6spd
    01duramax6spd Recruit
    187
    0
    May 6, 2008
    One of our Foremans did that too,turned out to be cut wire to the switch the dealer said.
  5. farmer0_1
    58
    0
    May 11, 2008
    cornelius, oregon
    i had him tap the starter with a wrench couple times he said it starts right up now. thanks for all the info i will keep it in mind the next time it won't start because you know it will leave you stranded when a tap tap gets you going. we will see if we can get his starter pulled off and looked at.
Share This Page
