Hole in the Intercooler tube
Discussion in '01-04 LB7' started by Pipepro, May 18, 2008.
  1. Pipepro
    Pipepro McMuddy
    58
    0
    May 10, 2008
    MI
    Well, I didnt see this thread here so Ill post up my Saturday afternoon work.
    After reading about several others with this problem and since I have had EVERY other malady that has come along, I figured mine must have a hole in it as well. Pulled the inner fender, and sure enough, there it is. What a silly bend in that power steering hard line, seems like it could have been prevented but oh well. Pulled it off, cleaned it with some break cleaner and filled the hole with JB weld. Let it cure overnight, then took some sheet rubber cut into a 2" wide strip, wrapped it around and used some 3M weatherstrip adhesive to glue it in place. Added a few Zip ties to keep it in place till it cures. I dont have a boost gauge, so I dont know how much I was losing or gained with the fix.
    [​IMG]
    [​IMG]
    [​IMG]
  2. Unit453
    Unit453 Cruises comfortably at 140... Staff Member Administrator
    7,124
    4
    Feb 10, 2008
    Bradenton, FL
    Shew...Did you hear it or feel any difference?
  3. Pipepro
    Pipepro McMuddy
    58
    0
    May 10, 2008
    MI
    My hearing is shot (literally) but some friends said they thought it sounded like a high pitched air leak, I did notice it had more passing power on the drive home. I only checked it because I saw some pics of a similar hole and figured I had better check mine out. The computer said we were getting better MPG's but Ill have to wait for some hand Calcs to verify. I did adjust the clamps a bit and used some tie wire to help hold it up off the line to prevent further damage. Ill check it again next oil change and see how we are doing.
  4. psyco66
    psyco66 Pimp
    149
    0
    May 13, 2008
    San Mateo, CA
    WOW I did not know about that. I am going to pull my inner fender tommarrow and check mine. That sucks. Wonder how long the motor has been sucking dirty air.
  5. Pipepro
    Pipepro McMuddy
    58
    0
    May 10, 2008
    MI
    I think that since it is in the intercooler tube it should be under pressure from the turbo, least I hope it is? Even at lower engine speeds there should be some boost. (I dunno, I dont have a boost gauge yet) The funny part is that the elbow from the steel line fit perfectly into the groove in the tube, I hope that would keep out most of the big chunks anyway. :mad:
    EDIT: I reached down from the front along the fan shroud and dug my fingers under the tube, wasnt easy to reach but I could feel there was some kind of dent or gouge where the hard line was rubbing. Thats what prompted me to pull the inner fender and get busy. I managed to bust a few of the silly plastic rivet thingies in the process, so pick up a few spares before you begin (and then let me know where you find em) :yesnod:
  6. psyco66
    psyco66 Pimp
    149
    0
    May 13, 2008
    San Mateo, CA
    I am sure the dealer has the rivit things. I have pulled the Passenger side inner fender a couple of times and I have never broke any of them.
  7. jfa3189
    jfa3189 New Member
    4
    0
    May 12, 2008
    hamilton, MA
    do you have a boost gauge? im running around 23 psi at 3000 rpms with a ppe boost valve is that low or normal? should i be looking for a hole or a leak?
  8. Pipepro
    Pipepro McMuddy
    58
    0
    May 10, 2008
    MI
    I dont have one, but from what I have read, the stock boost is around 20-24 and with the ppe valve it is more like 26-30? Dont quote me on it, but I think thats purty close. I would look around at your fittings and for the dreaded intercooler tube hole.
  9. WhitetailAddict
    WhitetailAddict Recruit
    260
    0
    May 9, 2008
    Central Pennsylvania
    Mine has a groove wore in it. I didn't feel a hole. I put some sheet rubber between the boost tube and the line and zip-tied it in place. I hope that works until I can do a permanent fix.
  10. SfcJones
    SfcJones A(ACLU) SGT. SLAUGHTER
    3,504
    12
    May 3, 2008
    South Ga.
    dang it....going to have to check mine now...my hearing is pretty bad too,
  11. richard cheese
    richard cheese the MAIN muff hugga
    345
    0
    May 7, 2008
    WHAT???:smilielol5:
    so if im seein 25 psi with a tuner and a PPE boost valve...im prolly OK???
  12. btfarm
    btfarm 300,000 Worth Staff Member Moderator
    16,098
    1,382
    May 12, 2008
    Sandwich, Illinois
    Damn... There ya go gettin' me paranoid. Another thing to wonder about next maint cycle in the next week or so. Does it look like an assembly issue? Like maybe if the CAC hose and tube were installed a bit better that there would be ample clearance? Haven't really heard of this one before.
  13. Tileman2003
    Tileman2003 Tim the Tileman
    152
    0
    May 17, 2008
    Northern CA
    It's been around on the other site checked mine and found it warn about half way through, wrapped it with rubber hose and trying to find time to do a permanent fix...
  14. Crazy_Steve
    Crazy_Steve aka SSchmi5519
    6
    0
    May 23, 2008
    Arizona
    Greaaat, now i gotta go look!
    And it's raining! In AZ! In May!
  15. fbh31118
    fbh31118 Cadet
    49
    0
    May 9, 2008
    Augusta, Michian
    I'm convinced. I'll check right now.
  16. btfarm
    16,098
    1,382
    May 12, 2008
    Sandwich, Illinois
    It occurred to me that the reason I wasn't aware of it before is maybe it's just an LB7 or early LLY thing... yes, no ?
    I've only had late LLY and LBZ.
    I'll be checking anyway...
  17. WhitetailAddict
    260
    0
    May 9, 2008
    I think it is just an LB7 thing.
  18. Diesel Dually
    Diesel Dually awaiting your return...signed... your friends
    506
    0
    May 3, 2008
    Mile High
    It may be an LB7 thing...mine gave up the ghost in a similar fashion....$400 to R&R it.
  19. richard cheese
    345
    0
    May 7, 2008
    it is...on the lly's there is sufficient clearance...although ifyou had any motor work done...and the tube isnt re-installed properly, then it could happen
  20. Foreman00081
    Foreman00081 New Member
    66
    0
    May 12, 2008
    Rochester, NY
    hmm, gonna have to go check mine, thanks for posting the pics
Share This Page
