headlight
Discussion in 'Exterior' started by gearhead, May 23, 2008.
  1. gearhead
    gearhead Harley Man
    71
    0
    May 8, 2008
    99 power stroke: how do you get the headlight out? the hole headlight Assembly that is
  2. gearhead
    gearhead Harley Man
    71
    0
    May 8, 2008
  3. dentpusha
    dentpusha LOCKED&LOADED
    881
    0
    May 9, 2008
    a-town texas
    does that one have the orange light on the side.if it does take it out then i think its a 7mm bolt on the side
  4. dentpusha
    881
    0
    May 9, 2008
    a-town texas
    post a pic i will kno more.i take out all kinds of headlights just cant recall what that one needs.ford is the hardest to remove.remove the 2 clips on the top then reach down behind the light and you will see a plastic knob squeez that together and the light should come out toward you.also undo the light bulb harness.try not to bend those 2 clips or they will be hard to put back
  5. gearhead
    gearhead Harley Man
    71
    0
    May 8, 2008
    thanks. cant take a pic because it is 30 miles away. same light on the 99 to 03 superduty's
Share This Page
