Head gasket or EGR cooler?
Discussion in '06-07 LLY/LBZ' started by tysmith, May 18, 2008.
  1. tysmith
    tysmith ZF Handshaker
    13
    0
    May 10, 2008
    RI
    Here's the deal. I have oil and coolant on the rear of my right (passenger) head. I believe the oil is coming from the PCV, blowing out of the rear of the EGR cooler. I have it blocked, obviously a bad gasket seal...
    I am entertaining the thought that it could be coolant coming out, too. I've added about 2 pints of coolant over the past 30k miles.
    I was curious if anyone else has had similar issues. If it's getting head gaskets, it's getting studs. Just don't want to go that deep if it's the EGR cooler...
    Might be time to bypass the coolant lines to the EGR cooler and see if the ooze comes back...
    Ty
  2. Chromer
    Chromer Ain't no Recruit
    56
    0
    May 10, 2008
    Northern Illinois
    Or go with a coolant dye. They work wonders at finding small leaks
  3. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,535
    56
    May 3, 2008
    Lithia, FL
    Probably not head gaskets because they tend to blow all the coolant out of the surge tank and leave a black residue (soot) in the tank.
    Are you still under warranty?
  4. tysmith
    13
    0
    May 10, 2008
    RI
    Yeah, still under warranty, but I'm not going to send it in for one. I'll probably wait and pull it to do head studs and new gaskets, both sides. I'll see if it gets worse. Hell, I could split a piston pulling and be yanking the thing out anyway...
    I was curious if anyone else had noticed anything similar. My buddy's '01 was weeping in the same spot as mine, and never got worse. didn't get better, either...
    Ty
  5. ServiceOnSite
    ServiceOnSite New Member
    12
    0
    May 21, 2008
    havent noticed that but i did just notice that the lines the dealer replaced for my powersteering are leaking again and now i have 40k on the truck:mad:
    so i guess this means im gonna have to fix them my self
Share This Page
