Frame Bounce / Frame Beaming
Discussion in 'Steering, Suspension and Wheels' started by BigDogYJ, Aug 20, 2009.
  1. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    Ok so I came across a thread on another forum that mentioned a condition (mostly 1/2 ton drivers) that had an issue with the frame bouncing over the concrete sections of freeway. Some reported it was so bad they couldnt talk without it sounding like they were getting bounced up and down.
    Anyways. I was looking into it. GM has a Campaign #PIT3009J that was released regarding this. It only applies to Ext and Crew cabs, not Regular Cabs and its been called "Frame Beaming". Apparently they did some research on this and came up with a new ear body mount setup. Long Story short, I ordered them and installed them last night. Damn! it actually makes a difference. Below is the test pasted from the GM Campaign.
    i know this was a big complaint with the 1500 trucks, but I think us 2500/3500 guys just assume thats how these are supposed to ride? I dont know. but I am extremely happy now. I have the Bilstein's and Sulastics from Nor-Cal Truck, and now this. Still a truck, but smooth and controlled like it should be.
    I installed mine last night and I am very impressed. If you have any questions or info, post up.
  2. Mad Maxx
    Mad Maxx See, what had happened was... Staff Member Moderator
    5,995
    118
    May 3, 2008
    Long Island, NY
    Yep, still got my Cab Mounts in the Box, just gotta find some Time to put them in.
  3. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    I didnt give it a chance. Received them yesterday, installed them last night with a floor jack and 4x4 post in about 45 minutes. I also installed the insulator for the front body mounts as I was getting a popping noise up there. All quiet and smooth now.
  4. Pepperidge
    Pepperidge Member Advocate Staff Member Lead Moderator
    12,353
    341
    Feb 10, 2008
    Slidell, La
    what year models will this work on?
    I'd like to change the front isolators as well because I get a popping noise also...but it is only on left turns and braking (odd) I've brought it into the shop a couple times and no one can find the popping cause...this may be it...
  5. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    From what I have found, it applies to all GMT-800's (ie. 2001-2007 classic).
    The isolator/insulator is basically a flat thin plastic washer that goes between the upper body mount and the frame bracket. I assume its to allow the body mount to move a little without binding or sticking (hence causing the pop).
    I also noticed mine when braking turning left usually into a driveway or something similar. No more noise now. I'll be leaving tomorrow on a 600 mile trip towing a 8000# trailer. So if it doesn't come back after that, I am going to assume its all good.
    Body Mount Insulator GM Part # 15899719 (~$2.50 each) One needed per side. Some have mentioned they have the same pop noise from other body mounts. So you may need more. But most likely its just the front mounts under the A pillar.
    I ordered mine through PartsZone Online along with a few other things. They seem to have better shipping rates than what I've seen on GMPartsDirect.
    I'll see if I can find the GM article for this.
  6. jrkrace
    jrkrace Recruit
    550
    0
    May 9, 2008
    Connecticut
    I did this about a month ago and it cut my passenger seat "shake" by about 90%. Truck is much smoother and dialed in nicely with my Sulastics and Monroe Reflex shocks.
  7. Pepperidge
    12,353
    341
    Feb 10, 2008
    Slidell, La
    Thanks...what were the prices for the new body mounts?
  8. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    I think when I got them, it was all like $74 plus Shipping.
  9. Pepperidge
    12,353
    341
    Feb 10, 2008
    Slidell, La
    wow... partszone total before shipping for both upper and lowers + isolators (2@$2 ea) came to $118
  10. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    Yea, when they First came out, I think for the Set the Price was like in the $50's, then I Ordered and it was in the $70's, I guess it's even more now.
  11. jrkrace
    jrkrace Recruit
    550
    0
    May 9, 2008
    Connecticut
    118.00 is what I paid for mine before shipping.
  12. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    $118 sounds in line with what I paid. I added a few other things on the order. so my total was a little more.
  13. BigDogYJ
    BigDogYJ Recruit
    348
    2
    May 8, 2008
    Kommifornia
    found my invoice. heres what i paid.....
    Qty Item ID Description Unit Price Amount
    2 25791031 cushion 27.00 54.00
    2 25791032 cushion 27.00 54.00
    2 15854745 retainer 2.68 5.36
    4 15899719 insulator 2.36 9.44
    Subtotal:$122.80
    Shipping:20.00
    Total:$142.80
  14. Pepperidge
    12,353
    341
    Feb 10, 2008
    Slidell, La
    the invoice was pending invoicing through paypal...
    I upped the isolators to 4 and instead of $140 through partszone with only 2 isolators...
    I got it all(what you ordered) for $133 through gmpartsdirect shipped
    thanks for all the part #'s and help :)
  15. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    4
    May 5, 2008
    NE Ohio
    All this stuff makes me real glad I have my old trucks, glad yall got a fix though!
  16. Pepperidge
    12,353
    341
    Feb 10, 2008
    Slidell, La
    Justin,
    the only thing really messed up is the isolators($2ea)...the other "fix" is really a ride preference... if you didn't know it was supposed to be better you wouldn't even realize it...I would guess after climbing out of an old 3500 and into a new(er) 3500 you would be thinking they are a cadillac...and that's without the body mount fix...JMHO ;)
  17. DEERE3594
    5,009
    4
    May 5, 2008
    NE Ohio
    sorry Pepp, just in a real bad mood today. I need to get off here for awhile
  18. Pepperidge
    12,353
    341
    Feb 10, 2008
    Slidell, La
    go spend some time with the little one...
    speaking of...got any recent pics? :)
  19. DEERE3594
    5,009
    4
    May 5, 2008
    NE Ohio
    wifey and little one are gone for a few more hours... ill have to get them off her camera when she gets back! :thumbsup::thumbsup:
    sorry for derailing yet another thread :eek:
Share This Page
