ford/dodge dually wheels? will they fit chevys?
Discussion in 'Steering, Suspension and Wheels' started by dmaxx3500, Dec 26, 2009.
  1. dmaxx3500
    dmaxx3500 Deputy
    3,204
    3
    May 3, 2008
    chicago,
    anybody try to put dodge or ford alum or steel wheels on a gm dually?,,i know the center hole is different,what size is the center hole ,,are these all hub centric?,,and how about the offsets?
  2. malibu795
    malibu795 misspleelleer..........
    961
    0
    May 7, 2008
    south charleston ohio
    all years dodge yes
    ford prior to 80 yes anything newer no they are 8x100mm
  3. dmaxx3500
    dmaxx3500 Deputy
    3,204
    3
    May 3, 2008
    chicago,
    what i need to figure is the center hole diameter,so i can see if i need to make up a filler ring
  4. 96 OILBURNER
    96 OILBURNER Member
    443
    0
    May 12, 2008
    Ludowici, GA
    I don't know about your 06, but the lug pattern on the Ford wheels is metric and wont work on the 90s models. Tried one on my 96.
  5. dmaxx3500
    dmaxx3500 Deputy
    3,204
    3
    May 3, 2008
    chicago,
    yep late model fords won't work,but you could have them re-drilled ,,my main concern is the center hole diam.,
  6. dmaxx3500
    dmaxx3500 Deputy
    3,204
    3
    May 3, 2008
    chicago,
    doesent anybody know the center dia's,?
  7. GM Guy
    GM Guy Manual Trans. 2WD Enthusiast
    4,662
    440
    May 6, 2008
    NW Kansas and SC Idaho
    I will say that GM has used a tight, small hub centric SAE pattern wheel , dodge is sae, but besides that, IDK, and ford, write them off, as they have been metric for a while.
    I am on dial up, so rather than go there and tell you, Ill let you go there yourself and look it up. the website is southwestwheel.com, and on that page, look around, and IIRC there should be an image with print that says OEM replacement accuride wheels. click on that, and it should give you what you need.
    good luck!
  8. dmaxx3500
    dmaxx3500 Deputy
    3,204
    3
    May 3, 2008
    chicago,
    nobody ever figired this out?
  9. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,539
    63
    May 3, 2008
    Lithia, FL
    I think I remember reading back on the other place a long time ago that the center hole in the dodge wheels is larger than the gm's. It was a big argument over whether 'lug centric' dodge wheels could be used on a gm IIRC. Don't hold me to that, just going by my crappy memory.
    They both use(d) an 8 on 6.5" bolt circle. Fords use an 8 on 170 mm bolt circle and I'm fairly certain that the new gm's now use a metric bolt circle.
  10. GM Guy
    4,662
    440
    May 6, 2008
    yeah, saratoga is correct. dodge and GM went metric for 2011 model year.
Share This Page
