Fluids and quantities
Discussion in 'Maintenance & Fuels' started by ZF6 MAN, May 14, 2008.
  1. ZF6 MAN
    ZF6 MAN The Unwritten rule
    30
    0
    May 3, 2008
    Lets get a thread going here on which fluids everyone is using and where. This will make for a good list of fluids for future questions. I will start, lets try and keep this thread to a list of fluids and capacities only.
    Enigne Oil: Mobil Delvac 1, 10 Qts.
    Engine Coolant: Dexcool, recommend dealer flush and fill
    Front trans axle: Mobil Conventional 80W-90 Gear oil, 2 Qts.
    Transfer Case: Mobil 1 5W-30 engine oil, 3 Qts, (ATF Recommended by GM)
    ZF6 Manual Transmission: Mobil Fully Synthetic ATF, 6 Qts.
    Rear Axle: Mobil 1 Synthetic 75W-90 Gear oil, 3.5 Qts
    This should be a good starter for a reference. Remember, this should be what you use in YOUR truck to show different perspectives.
  2. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    Engine - Amsoil Heavy duty marine grade
    Axles - Amsoil severe gear
    The rest is OEM for now
  3. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,535
    56
    May 3, 2008
    Lithia, FL
    Engine: Either Delo 15W40 or Delvac 15W40 (which ever is available at the time) 10qts
    Trans: TranSynd ~5gal
    Rear Diff: Mobil-1 75W90 4+qts
    Power Steering: Transynd ~2qts
    Coolant: Dex-Cool and DISTILLED H2O
    Fuel Additive: Wal-Mart TCW-3 two stroke oil~ 0.5oz/gal
  4. joverman
    joverman Recruit
    18
    0
    May 8, 2008
    Harmony, NC
    Engine: Rotella 15w40 (switching the Rotella 5w40 full synthetic next oil change)
    Trans: Mobil 1 Dex VI (switching to TranSynd at next oil change)
    Rear Diff: Mobil 1 75w90
    Front Diff: Mobil 1 75w90
    Coolant: Stock
    Transfer Case: Mobil 1 Dex VI
Share This Page
