FICM leaking fuel
Discussion in '01-04 LB7' started by dieseldummy, May 16, 2008.
  1. dieseldummy
    dieseldummy New Member
    2
    0
    May 16, 2008
    Well, my '01 is at the dealer getting it's first set of injectors put in (112K) and during disassembly they found that the injection control module is leaking fuel. I was just wondering if this is a common problem and if there is something I should do different when it goes back together. The dealer want an arm and my first born for a new one so I'd like to find the cause if I have to buy a new one. Hopefully I'll find a used one though.
  2. WhitetailAddict
    WhitetailAddict Recruit
    260
    0
    May 9, 2008
    Central Pennsylvania
    I never heard this as a common problem. I have heard it occur when you run too much fuel pressure with a lift pump. Check ebay for a used one, I saw a few on there.
  3. whitetrash21
    whitetrash21 Put on the damn helmet day........
    788
    0
    Apr 29, 2008
    Vegas
    heard the same ^^^.. only seems to be an issue on the lb7/lly trucks. gm did something different with the lbz/ lmm trucks so this isn't an issue... or so i have heard.
    ebay is a good place to start. might check with gmpp... dunno if they carry stuff like this but worth a shot.
Share This Page
