Engine oil cooler kit
Discussion in 'Leroy's personal forum' started by Burning oil, Apr 7, 2009.
  1. Burning oil
    Burning oil LeroyDiesel.com Vendor
    10,130
    1,449
    Jan 3, 2009
    Houston
    I am now selling an engine oil cooler kit.
    This is a direct replacement cooler and custom hoses. The cooler bolts right where your stock cooler was. You will reuse the brackets from the core suport to the cooler. The hoses are rated to 300 psi and 400 degrees F.
    $199.00 + shipping. www.pmdcable.com
  2. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Dtr member special
    For DTR members only!!
    I am going to offer a Perma Cool oil thermostat for my oil cooler kits.
    You will have the option of
    1. A free perma cool oil thermostat
    OR
    2. $40 off the price of the cooler kit = $159. for a kit w/out thermostat.
  3. ak diesel driver
    ak diesel driver 6.5 driver
    11,723
    1,151
    Feb 7, 2009
    alaska
    Will your offer be good next winter?
  4. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Should be, you will just have to get with me at that time.
    Also, just alittle FYI. This cooler is made by the same company that makes the B&M cooler, but witout the B&M name, so it costs less!
    The hoses are made with industrial stentgh hoses and are availible in "stainless steel braided teflon lined" hoses as well.
    Before you buy anywhere else ask me and I will beat the price. The quality of this kit is exactly the same as you would buy anywhere else we just charge less for it and include a free oil thermostat.
  5. GM Guy
    GM Guy Manual Trans. 2WD Enthusiast
    4,608
    379
    May 6, 2008
    NW Kansas and SC Idaho
    is this offer still good?
    Also, would you recommend the t-stat for my climate, or is it best reserved for the canadian climate?
  6. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Sorry guys, I did honor that deal as long as I could, but my cost on the hoses and cooler went up. $199 w/out thermostat.
    The tstat mainly allows quicker warm up.
  7. 88gmctruck
    88gmctruck 02GMCtruck
    1,954
    123
    Mar 16, 2009
    Auburn, Wa
    I'm curious what fitting the cooler itself uses (the thread size).
    I'm adding an external cooler to my 88 and have the stock lines for the cooler (the ones with the o-ring seal). Does this kit work with stock style lines? If so, is the cooler available separate?
    Or possibly, anyone who has upgraded their setup have their stock cooler left over and want to part with it?
  8. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Hi, ports on my cooler are 1/2" pipe. Won't work with stock hoses.
  9. dangerousdave
    dangerousdave Brain Damaged Diesel Junkie
    Thanx again for the quick service, Walbro, oil cooler and fittings, OPS ext kit ; all well recieved.
    So, which is it, League City or Webster?
    I was working the Houston area for 12 years; Freeport to Conroe, Sealy to Mont Belvue.
    Lots of great people down there.
    Lived near Jersey Village, FM1960... We could put on some coffee and tell some lies, er stories. :rolleyes5:
  10. Dan Hunter
    Dan Hunter Truck Terrorist
    441
    2
    May 27, 2008
    Enid, OK
    A bit of a bump here.
    I finally got around to installing my lines I'd purchased months ago. Other than a bit of grinding on the exhaust flange, there were no surprises...on the install.
    The replacement factory lines that came out were a bit of a surprise. One of the lines was off angle to the flow and looked like it was about to come off!
    Whatever you do, pull you factory lines and replace them. Burning Oil, thanks for making these kits available. Yeah, I could have gone to the trouble of assembling all the fittings myself and...wait, no I couldn't.
    Again, thanks.
  11. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Hey thanks Dan, I see in your signature you have another vendor listed for your Oil cooler kit? Did you buy it from me? sorry I can't remember that far back.
    Glad you got her fixed up.
    Leroy
  12. dangerousdave
    Your kit (Leroy) is great. I just wish you had an instruction like," using a sawzall, bolt cutters, or a cutoff tool, remove old hoses... don't try to save this old junk, as it WILL be trashed and you can't sell it on flea-bay."
    Of course, if you had worked for GM and made them put this system on at the factory, you'd get nothing back.
  13. Burning oil
    10,130
    1,449
    Jan 3, 2009
    Houston
    Thanks Dave, I appreiciate that.
  14. GM Guy
    4,608
    379
    May 6, 2008
    thought i would give an update on your kit. installed it this spring, rightbefore a jaunt to idaho,to california, back to ID from CA, then back to KS. no leaks, all and all pretty good deal. good thing we changed them too, as they were seeping pretty good at the block connection.
    I would recommend everyone to do something about their OEM lines, as they are a problem.
  15. great white
    great white Well-Known Member
    Anyone have installed pics?
  16. dangerousdave
Share This Page
