Do you maintain your ride?
Discussion in 'Maintenance & Fuels' started by saratoga, May 7, 2008.
  1. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,539
    63
    May 3, 2008
    Lithia, FL
    Just curious how many folks (speak up Ford and Dodge guys too :D) like to wrench on their trucks. I do it mainly because I enjoy the stress relief and it's a good time to check things out. That and no one takes care of my stuff like I do. The dealer has yet to do any type of PM on my truck in the 3 years I've had it.
    What kinds of things will you do such as tire rotation, basic fluids, etc?
    What oils and fluids do you like to use? Do you like to have a UOA done every so often and how do the numbers look with your maintenance intervals?
    I like to use either Delo 400 or Delvac 1300 and NAPA/ WIX oil filters and Ally OEM trans filters. Usually do my maintenance on 5,000 mile intervals.
  2. BudTX
    BudTX Edjumacated Redneck
    Oil and filter every 5k or so.
    Lube every 7-10k.
    Rotate tires every 6k or so.
    Fuel filter every 10k, but I'll stretch that out to 15-20k with the FASS that I have now.
    Tranny spin-on every 15k. I only have 13k on my tranny since going with Transynd, so that will stay for a while.
  3. nosliw
    nosliw Recruit
    331
    0
    May 3, 2008
    i do my own because i don't trust anyone at a dealership with my truck. i trust good diesel shops - but i can't afford them.
    oil + filter @7,500
    fuel filter @15,000
    tranny filter @10,000
    tire rotation @10,000
    tranny fluid @...... truck has 40K on it and hasn't been changed yet. procrastinating since 25K...:queasy:
  4. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    oil/filter- when dic tells me, usually 7-8k with amsoil filter and 15-40
    tranny spin on- with oil change I use OEM
    fuel filter- every 5k with OEM blue acdelco
    trannyfluid- 15k with amsoil torquedrive, internal filter every 30k
    diff's- 30k with amsoil severe gear
    transfer case- 15k next replacement will be with amsoil 5-30 motor oil
    lube everything- 5k
    tire rotation- with oil change.
    I know I go overboard but the truck sits more than it used to now.
  5. Tom S.
    Tom S. Killing time
    75
    0
    May 4, 2008
    Waterford, MI
    I have been doing my own maintenance since I started to drive (over 40 years ago), with very few exceptions. Combination of being frugal (cheap) and not trusting $8 an hour "mechanics".
    However, as I've gotten older and cars gotten more complicated, I have backed away from major stuff (removing heads, rebuilding trans, etc.).
  6. GM Guy
    GM Guy Manual Trans. 2WD Enthusiast
    4,679
    455
    May 6, 2008
    NW Kansas and SC Idaho
    I do My own because i am young and broke! :cheers2: Although the dealer has the famous 19.95 oil change, i don't know the quality of filters/oil and quality of work, so i tend to just do my own. I like to know what is going in, and what is going out (check for shavings!)
    My gasser has been in our shop waiting for u-joints (greaseable, of course!) pinion and tailshaft seals, and then a full drivetrain synthetic oil change.
  7. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    30
    May 4, 2008
    McHenry,IL
    Since I bought my 1st truck, I have done all the routine maintance on my trucks. Just something that makes me feel better of how my truck is being taken care of. I use AC Delco filters for oil and fuel, Mobil 1 Delvac 1 oil. Also use Mobil 1 lubes and Fluids.
    Oil/Filter- 9-10k
    Fuel Filter- 10-15k
    Spin on Trans Fliter- done ever oil change (if I'm down there already doing the engine oil, I figure I might as well to the spin on.
    Diff's- Try for around 30k
    Tire Rotation- 8-10k
    Trans Fluid- 30k when I do the Diff's
    Lube- Every Oil Change
  8. MGlickLBZ
    MGlickLBZ Agent Quack Smacker
    234
    0
    May 5, 2008
    South Central, WI
    Between business, camping trips, running kids here and there and helping take care of my mother, I don't have the time to do it myself. I have a buddy in town that does it all for me, I supply all the filters and oil etc and he charges me like $20 an hour for the labor.
  9. I do my own LOF, including changing out all the fluids for Amsoil (except the tranmission). I installed my escalade handles inside and out, as well as the hood shield. I have also done the allo n headlight mod, and a diet version of the PPE airbox mod. (I left the fins but trimmed out the round center)
    I've had the dealer:
    -Take apart my passenger door to clean debris from the track and lube everything.
    -Replace the relay center when my lights wouldn't stay on (relays weren't contacting when seated).
    -Replace the "Info/Tune" button on my radio when I wore the black off of it.
    So yeah, if it's maintenance, it's me; if it's warrantiable work, they do it.
  10. truckie481
    truckie481 Dagum
    682
    0
    May 4, 2008
    Cleveland, NY
    I do every thing myself, I let the dealer take care of warranty work only but that ended at 36K so now its all me. I like Amsoil products, engine and diffs but I stayed stock on the tranny and T-case. I add Power Service at every fill up.
  11. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    I do minor wrenching on the trucks...installing parts like intakes, exhausts, I do all the programming and the oil changes too..tire rotation and balances are done elsewhere and major stuff is done elsewhere...
  12. LiftedLaramie
    LiftedLaramie Recruit
    93
    0
    May 6, 2008
    CO
    the tediouse shit like oil changes and tranny services are done at a shop that my employer has an account at. Its easy and cheap so cant really beat that, but mods are done by me...
  13. duratothemax
    duratothemax Recruit
    65
    0
    May 5, 2008
    I do everything myself. I built the engine, tranny, tuning everything. No one else touches my truck.
  14. gearhead
    gearhead Harley Man
    71
    0
    May 8, 2008
    it's me or nobody.
  15. upbrakie
    upbrakie Recruit
    26
    0
    May 9, 2008
    Topeka, KS
    On my Ranger, I've done all oil changes and tranny fluid changes since 24,000 miles. I've also done brakes, and other wear items, as well as replacing a rear axle oil seal and bearings a few years ago.
    I just got my 2500, so I haven't done anything major yet, but plan on doing all the fluid changes as well as seeing what else I can tackle.
    I haven't been doing the oil changes on my car as I don't quite fit underneath. But, I'm getting less and less trustworthy of everyone else, so I may start doing it myself.
    My dumptruck, I've changed to plugs, distributor cap, rotor, plug wires, oil, filters, and did some rewiring, but I have a friend doing rear brakes right now, as I didn't want to even try to tear down the rear duals on a big truck
  16. BigBlueBurban
    BigBlueBurban Umm no...WAIT...yes
    98
    0
    May 7, 2008
    Grand Rapids, Michigan
    I do most of the work myself. Great stress relief. I leave fluid changes to a trusted shop, otherwise I'm the one turning the monkey's wrench:biggrinjester:
  17. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    i try and do everything myself. when it comes to sensors and electrical issues (ie, the service air bag message that's been on for 2 months), it goes to the local garage. i'm getting ready to swap my tranny fluid for transynd, that'll be as in depth as i'll ever get with the transmission.
  18. gc427
    gc427 Diesel Mark
    64
    0
    May 4, 2008
    Anaheim, CA
    I do all of my own maintenance.
    The only thing done on my truck by someone other than me was tire changing. I do not have a tire machine or tire balancer.:mad:
    The next thing that will be done on my truck by somebody other than me will be the transmission. Guess who [​IMG]will do that when the time comes? [​IMG]
  19. Chromer
    Chromer Ain't no Recruit
    56
    0
    May 10, 2008
    Northern Illinois
    I'm with ya on that one... NO ONE touches my truck.
    I won't even take her in for warranty work. Luckily, I don't need much.
  20. got-h2o
    got-h2o HillBilly Pimp
    313
    0
    May 10, 2008
    NW Indiana
    I've always worked on my own stuff and always will. But................I've been getting lazy the last few years. I have great connections at the dealer and get most of my maintenance done there. I couldn't tell you the last time I paid for an oil change, rotations, fuel filters, etc. Larger repairs usually get chalked up to warranty too. I also know the techs that work on my truck, and they are trustworthy. I guess I'm one of the lucky ones. :ciappa:
    Aftermarket add on's (large or small) and misc tinkering still gets done by yours truly.
Share This Page
