DIY Oil Cooler Lines (Small Lines)
Discussion in 'GM 6.5 Diesel Engines' started by NVW, May 8, 2008.
  1. NVW
    NVW Well-Known Member
    8,458
    820
    May 5, 2008
    Castor, AB.
    I got the hose and fittings at our local Bumper to Bumper/ tire shop/ farm supply place. Castor is a small town so one store supplies many things. The hose is 1/2" double braid hyd. hose. The block 90* fittings have 3/8" male npt. on one end and 1/2" JIC. on the other end(part # JCM06-NPM08). One end of the hose has a crimped on fitting that has a 1/2" compression fitting to go on the original 1/2" aluminum pipe that was cut below the rad (GoodYear part # B2-FTM-0808). The other end of the hose has a 1/2" JIC. female swivel that is crimped on the hose (part # B2-JCFX-0808). The total length of one hose with fittings is 42" the other is 44". I had to remove about 1/8" of material off of the filter housing edge because of interference with the hoses at the 90* fittings. Leo
  2. 94K30
    94K30 Diesel nut
    230
    0
    May 9, 2008
    manchester CT
    nice job..... and by the way, like the color of your truck too....
  3. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    5
    May 5, 2008
    NE Ohio
  4. muddycowboy
    muddycowboy BERR
    17
    0
    May 17, 2010
    randolph oh
    was your filter housing a pain to get lose mines being a bit stubbern and im affraid to crack it with a impact but the 2ft breaker isnt doing it. any tips?
  5. NVW
    8,458
    820
    May 5, 2008
    Castor, AB.
    Mine came off easy, you are talking about the 4x4 adapter housing?
  6. muddycowboy
    muddycowboy BERR
    17
    0
    May 17, 2010
    randolph oh
    yeah directly above the front axle shaft like a 1 1/4" nut
  7. bison
    bison Well-Known Member
    3/4" drive socket(grind a flat on the hex side, the bolthead is kinda shallow),extension,ratchet and 4' snipe and give'r,you wont break the bolt or the housing
  8. bison
    good job:thumbsup:
    You not afraid the hoses are to close to the manyfold and will get burned?
    I made mine out of 1/2 hydr tubing most of the way before going hose
    BTW,i got same color trucky
  9. NVW
    8,458
    820
    May 5, 2008
    Castor, AB.
    2-3 yrs and no problem yet, no accounting for good taste:thumbsup:
  10. bison
    and you post that only now!
    You Roderiqus slowpoke or something?:rolleyes5:):h
  11. NVW
    8,458
    820
    May 5, 2008
    Castor, AB.
    You're getting old, this was posted when we moved here. It's a re post from the Place.:D
  12. bison
    thanks for clearing that up:thumbsup:
    i was'nt sure myself how long i had left :smile5:
  13. NVW
    8,458
    820
    May 5, 2008
    Castor, AB.
    lol, we're all getting there:grouphug:
  14. Diesel -T
    Diesel -T Recruit
    184
    0
    May 9, 2008
    Love these posts .
  15. Nice clean install...might ya remember the approx cost?
  16. NVW
    8,458
    820
    May 5, 2008
    Castor, AB.
Share This Page
