Changing headlight on 97 Chevy 3500 (Chrome, non-W/T)
Discussion in 'Electrical' started by Matt Bachand, Apr 17, 2011.
  1. Matt Bachand
    Matt Bachand Depends on the 6.5
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    I have the bulb. How does the headlight release or do I remove the batts?
  2. WarWagon
    WarWagon Well it hits on 7 of 8...
    7,197
    1,153
    Nov 15, 2009
    AZ
    Composite headlights come out by removing the two long black screws sticking up with the bolt heads. They stick out just above the lights. You have to raise the hood to see them. They are not the adjusters down in.
  3. Matt Bachand
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    thanks man, I thought they were adjusters :)
  4. Matt Bachand
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    Of course one of them wont turn.....
    What is an alternative if I can't get one out?
  5. Brooklyn Tow
    Brooklyn Tow 9 11 Never Forget
    3,212
    4
    May 6, 2008
    Brooklyn, NY USA
    You should be able to remove the socket from the headlight, replace the bulb, and put the socket back in.......wothout removing the entire headlight housing.
  6. Matt Bachand
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    One screw finally turned, but ended up cracking its plastic boss. Which ended up snapping off of the rest of the unit. It went back together fine, a few more cracks will go unnoticed :)
    Damn rust belt.... can't even change a headlight bulb :)
  7. WarWagon
    7,197
    1,153
    Nov 15, 2009
    AZ
    Do the filaments burn out up there or do they rust out before they burn out? :rof:
    You can get the entire headlight assembly including the mounting that went 'snap' on you for around $50.00. Course the risk of pulling the grille out... Much brighter light through new clear lenses I have found.
  8. bison
    bison Well-Known Member
    Koprkote is your friend
  9. jrsavoie
    jrsavoie Recruit
    5,341
    361
    May 8, 2008
    Rural Clifton, Illinois
    Where do you get headlightassemblies for $50? Last time I looked they were about $100 each or more
  10. Ed HD
    Ed HD Formerly: Dad's 05 LLY
    3,082
    251
    Jul 6, 2008
    Lakeville, Minnesota
    Wait, I didn't know that! I always removed my grille, LOL. Thanks for the info guys.
  11. jrsavoie
    jrsavoie Recruit
    5,341
    361
    May 8, 2008
    Are there any tricks or special tools for removing the grill without breaking pieces on the grills?
    All of my grills are broken somewhere.
  12. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    4
    May 5, 2008
    NE Ohio
    Im really lost. I always moved my battery a few inches back and did it. If you pull the grill, then you have to unbolt the 4 10mm bolts and take the headlight out right? I do sure like on the 2002 you just pull out them 2 pins and can change a headlight or parking lamp in 30 seconds :D
Share This Page
