Brake Flush?
Discussion in 'Drivetrain' started by saratoga, May 22, 2008.
  1. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,535
    56
    May 3, 2008
    Lithia, FL
    When the dealer does a brake flush, shouldn't that entail opening the bleeders at all four corners?
  2. precision37
    precision37 Recruit
    89
    10
    May 9, 2008
    New Hampshire, USA
    Yes, and using a Tech 2 to cycle the ABS to bleed it.
  3. saratoga
    4,535
    56
    May 3, 2008
    Lithia, FL
    Thanks.
    Looks like I need to have a chat with someone then.
  4. saratoga
    4,535
    56
    May 3, 2008
    Lithia, FL
    Going to bring the truck in to talk with dealer tomorrow. I'm slightly pissed.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. tomrex
    tomrex Professional Idiot
    Looks awfully dry down there to have been flushed...but it is possible that they hosed it down with brake clean or used a tube over the bleeder so there was no mess...just a thought. :)
  6. blizzardplowman
    blizzardplowman Crowd Control Staff Member Moderator
    655
    0
    May 3, 2008
    SE WI
    I would be asking a few questions.......Looks dry to me also.
  7. chevy_dmax
    chevy_dmax Recruit
    8
    0
    May 9, 2008
    I call bs, but i bet they will say they cleaned it. Cleanest bleed job in the world, call Ripley's. :icon_bs:
  8. WilliamBos
    WilliamBos Serial Post Whore in the making...
    So what happened??
  9. saratoga
    4,535
    56
    May 3, 2008
    Lithia, FL
    Here's the skinny:
    Last Sat, I went back to Autoway and had them correct the alignment that they messed up since the wheel was off center by about 1/8 turn. Wasn't happy, and I made that known but I didn't come across as a pissed off jerk ranting and raving. Asked what kind of machine they use to do the brake flush with... they told me it's a BG machine that performs some push-pull deal from the master cylinder and eliminates the need to open the bleeders at the calipers. "It collapses the calipers and pulls the contaminated fluid back to the master cylinder" they told me. Not agreeing with this, I just told them oh, okay and had them correct the alignment. In my mind, I know that's BS because how can you collapse 8 caliper pistons by sucking on the plastic master cylinder resivor without it caving in???
    Monday, I went to James-Rivard GMC which is closer to my house and paid them $35 for a brake inspection. I told them what I had just paid another shop to do and specifically asked whether or not it was possible to flush the fluid as described above and if it looked as if the service was performed. No to both counts. They cracked the bleeder on the LF caliper while I was standing there and nasty dark fluid came out, the opposite of what is in the resivor. We left it at that, and they put on my invoice "brake flush recommended".
    I've called and spoken to the GM of the Autoway dealer and he wants me to come in next Monday so that he can be a part of the discussion that I plan to have with the service manager. He also told me not to fill out any customer satisfaction surveys until they have the chance to talk with me in person. Can you say CYA???
    Bottom line: I very nearly got taken and the saga is to be continued...
  10. precision37
    precision37 Recruit
    89
    10
    May 9, 2008
    New Hampshire, USA
    This should be interesting, keep us informed. Ask them to show you their "majic" machine that sucks the brake fluid out past all of valves in the ABS module, and doesn't collapse a rubber brake line.
  11. psyco66
    psyco66 Pimp
    149
    0
    May 13, 2008
    San Mateo, CA
    They are very lucky they did not tell me that line of bull****. I would have been stomping some heads. I hate peace of **** dealers. Wonder how many other people they took for brake flushes. You should contact the better buisness buero (SP) and let them know about this.
  12. DEERE3594
    DEERE3594 I welcome everyone...not just Penguins!
    5,009
    4
    May 5, 2008
    NE Ohio
    I hope it works out for you saratoga. Ive never heard of this being done, how often should we flush our brake lines? Sorry to go off topic..
  13. whitetrash21
    whitetrash21 Put on the damn helmet day........
    788
    0
    Apr 29, 2008
    Vegas
    i used to rebuild and fix those"bg machines" you were talkin about. either the tech is really stupid or he is full of shiit... every time i used those machines on my rigs i had to crack all 4 bleeders. machine does all the work for you but you HAVE to open the bleeders. i have never heard of a BG machine that can pull the fluid out of a single direction line without causing some sort of vacuum. not doable, like you said, without collapsing the reservoir, or at least opening the bleeder, which will show fluid.
    as far as it being clean, i used to put a hose over the screw to catch the fluid. it caught the majority of it but there was still a little residual left on the dust sheilds..... liike you said, looks too clean to have been opened...
    hope you get it worked out. let us know.
Share This Page
