Big Diesel (ie BIG)
Discussion in 'GM 6.2 Diesels' started by cornemuse, Sep 13, 2016.
  1. cornemuse
    cornemuse Active Member
    Jan 11, 2013
    San Diego north county
    This will NOT fit in your truck!!!
    Turbocharged two-stroke diesel straight engine, 6 to 14 cylinders
    Bore 37.75 inch (960 mm)
    Stroke 8.4 feet (2,500 mm)
    Displacement 111,063 CI (1,820 litres) per cylinder
    Engine speed 22–102 RPM
    Mean effective pressure 1.96 MPa @ full load, 1.37 MPa @ maximum efficiency (85% load)
    Mean piston speed 8.5 meters per second
    Specific fuel consumption 171 g/(kW·h)
    Power Up to 5,720 kW per cylinder, 34,320–80,080 kW (46,680–108,920 BHP) total
    Torque Up to 7,603,850 newton metres (5,608,310 lbf·ft) @ 102 rpm
    Power density 29.6 to 34.8 kW per tonne, 2300 tonnes for the 14-cylinder version
    Mass of fuel injected per cylinder per cycle ~160 g (about 6.5 ounces) @ full load(Whole motor uses up to 250 tons of fuel per day.)
    Crankshaft weight 300 tons[
    Piston weight 5.5 tons
    Piston Height 20 feet
    FellowTraveler and btfarm like this.
  2. Big Ray
    Big Ray my two fat girls.
    Jan 8, 2016
Share This Page
