another SCIII question
Discussion in 'GM Allison' started by MattZ71, May 16, 2008.
  1. MattZ71
    MattZ71 Tennessee Diesel's Mod
    355
    0
    May 16, 2008
    KY/TN line
    ok, i will plan on buying a SCIII will it hold the ATS or PPE 270 tune with any problems??? and yall that have the SCIII how are the shifts??? will it bark the gears? thanks for input guys!
  2. TIM Z
    TIM Z Tie Rod Bender
    294
    0
    May 7, 2008
    Navarre, Ohio
    No prob, it will hold alot. Lots of guys running 500RWHP thru them . ask Mike L.
  3. BudTX
    BudTX Edjumacated Redneck
    I have the equivalent of a SCIV, and a 1057 converter. It handles my 350 PPE tune without problem. A properly installed SCIII will do fine with a 270 PPE tune.
    What year is your truck?
  4. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    i dont have one yet i hve my eye on three lly truck (04.5-05) i will have one of them im already buying stuff...alredy have a few things for a lly....lol and my next buy is a ats e-power on 270 tune only daily driver
  5. Mike L.
    Mike L. Recruit
    128
    0
    May 5, 2008
    SC3 will hold you just fine.
  6. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    thank you Mike ONE MORE question, when i go with the SCIII i will run the 270tune daily you said that will be fine, the other question is, ill will pull 3-4times a year at the most will it hurt anything if i us the 350 tune just to pull?? or will i be needing a co-piolt?? thanks!
  7. Mad Maxx
    Mad Maxx See, what had happened was... Staff Member Moderator
    5,995
    118
    May 3, 2008
    Long Island, NY
    ...Damn, if you are going to be using the 350 Tune to pull, I'd think your EGT's would be through the roof!
  8. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    what would be a good tune to pull with?? i have a 4" turbo back exhaust laying in the garage.....but no truck
    i no!! im counting my chickins before thay hatch
  9. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    Hell, I'd say no more than a 120hp tune for pulling. Of course it depends on what you are pulling. If you are pulling something so light the Truck won't even know it's back there, then yea, a 350hp tune will do.
    How much weight are you planning on pulling?
  10. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    street class 8500lbs no more!
  11. Mad Maxx
    5,995
    118
    May 3, 2008
    Long Island, NY
    Ok, I have 0 experience with pulling contests, so I'll back down, but if it were me, I'd still only run the 120hp.
    But people say you are good at a certain Max EGT for XX amount of time, so I'll let the experienced pullers step in.
    Just let everyone here know what your current / expected mods. will be at the time of the pull so it will give them a good guess as to what would be safe for you.
  12. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    will do! when i get the truck in a set up ill go from there!! THANKS MAN for helpin me!
  13. WanaDmxSub
    WanaDmxSub Recruit W/gray hair
    89
    0
    May 8, 2008
    Just incase you didn't know...
    *Horsepower numbers are represented at the crank.
    This is true for ATS and PPE
    I run a RWHP 230 tune when I sled pull.
    I run a RWHP 40 tune when I tow the TT.
  14. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    how does you SCIII like the 230RWHP? shot good and firm @ WOT?
  15. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    i was just wondering, i gotta cusin that has a SCIII and a TCI converter in a lb7 with the ats e-power on 350tune, it will limp when it goes it 3rd gear, maybe b/c he has a TCI converter??
  16. Mike L.
    Mike L. Recruit
    128
    0
    May 5, 2008
    How did he get a SC 3 without a SC converter?
  17. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    bought if off ebay, with no conveter...dont ask......just what i was told...i asket him the samething
  18. MAX4X4
    MAX4X4 Recruit
    54
    0
    May 4, 2008
    CA
    Mike L Suncoast III with PPE on 350HP, daily driven. Works awesome!
  19. JD4440
    JD4440 EFILive impaired.
    49
    0
    May 3, 2008
    350 ET PPE on a SC IV and Co-Pilot. NICE!!!!!
  20. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    pulling and towing are two different animals. i wouldn't hardly worry about your EGT's when you're pulling a sled down the track, as that's only 5-10 seconds and then your EGT's will drop after that. towing a camper for 500+ miles at a time is different. then i'd be worried about cooking my turbo while running a hot tune.
Share This Page
