Anaerobic sealer - what is it? where can I get it?
Discussion in 'GM 6.5 Diesel Engines' started by BigArt, May 31, 2009.
  1. BigArt
    BigArt In for the long haul
    204
    0
    Sep 12, 2008
    Winnipeg, MB, Canada
    I will be doing Heath's cooling upgrade starting Tuesday. Including pulling and cleaning the hell out of the radiator. I will plan on taking a bunch of pics to create some sort of "how to".
    But in the instructions it says to use an "anaerobic sealer". I've googled it and found out that it is a substance that will cure in the absense of air. And I understand what it is used for. Even got a Loctite and a GM part number (Locktite 518 & GM 1052943). I haven't tried the stealer, and am having a heck of a time finding anything off the shelf in the local auto stores. Anyone have any ideas where a Canuck can go to get this stuff? I don't think it's the same as RTV or silicone.
    Art
  2. schiker
    schiker Well-Known Member
    2,238
    292
    Nov 9, 2008
    Pendleton, SC
    I believe "The Right Stuff" is anaerobica. I think that is by Permatex. . I'd recommend "The right stuff" or GM PN from what I have read.
  3. Jasonsmack
    Jasonsmack Recruit
    115
    0
    May 9, 2008
    Swift Current, SK
    I think the "right stuff" is a urethane based silicone replacement.
    Our local NAPA and Auto Electric stores generally have the anerobic sealants. They are sometimes labeled as gasket maker. I think they were originally formulated to use on modular cases like snowmobiles, subaru's and air cooled vw's. It is unlikely that you will find it at the regular places like canadian tire and parts source.
  4. JMJNet
    JMJNet Recruit
    1,916
    84
    May 6, 2008
    Richardson, TX
  5. THEFERMANATOR
    8,517
    1,570
    May 9, 2008
    ZEPHYRHILLS FL
    NAPA or most large parts houses will have it(AZ and ADVANCE are more for do it yourselers). It is commonly called gasket maker and it will be a thick red paste. You can also buy it from EVINRUDE as GEL SEAL as it is also used for sealing engine case halves in outboard motors. It is a sealer basically used where tolerances are critical and a silicone can't be used due to torsional flexing of the parts. Manual transmissions commonly use it for the case halves as well. Just remember though to be careful cleaning surfaces that will receive anrobic sealer. They must be flat and clean and pull down tightly together. Otherwise the sealer will not harden as it requires pressure in the absence of air for it to cure.
  6. Matt Bachand
    Matt Bachand Depends on the 6.5
    5,330
    7
    Jun 10, 2008
    Worcester, MA
    Must be the same stuff you can see 'squishing' out between my T-Case.
  7. bk95td
    bk95td 6.5 nut job/addict
    2,548
    9
    Nov 26, 2008
    I bought a spray can of special anarobic prep at napa.It is acetone baced cleaner. There cant be any oil or anything else on the surfaces to be sealed.
  8. Acesneights1
    Acesneights1 New Member
    10,018
    10
    May 5, 2008
    Northeast CT
    Huh.. I missed that part when I did mine. I used plain old snot. No leaks.
  9. Missy Good Wench
    Missy Good Wench Wild Blonde from Cloud Mt
    1,683
    40
    Nov 19, 2008
    Newberg Oregon
    You dont need any of the $$$$$$$$$$$ stuff to do the job right.
    The correct way to do the water pump is to use a gasket (felpro or your fav brand)
    There is a gasket that goes between the water pump back plate and the Timing cover and also one that goes between the back plate and the water pump.
    Use a little High temp silicone on the surfaces to stick the gasket and your good to go.
    Be sure to use a little extra silicone at the water ports. Also place a little silicone on the threads of any bolts that go into the water jacket.
    Easy, simple and no need to spend big Bucks and fool with the anerobic sealer.
    That stuff was marginal anyway.
    MGW
  10. chevyCowboy
    chevyCowboy I might be crazy but i ain't dumb
    1,601
    32
    Nov 16, 2008
    Springfield Nebraska
    i used "the Right stuff" when i did mine and itnaint got a single leak i was told about it by a friend and it is now my favorit sealnt kinda pricey but it works great.
Share This Page
