Allison deep pan
Discussion in 'GM Allison' started by 12ga diesel, May 8, 2008.
  1. 12ga diesel
    12ga diesel Jack of all, Master of none
    1,766
    29
    May 4, 2008
    McHenry,IL
    Does anyone have any exp. with the factory Allison deep pan for the tranny? Does this work as well as one of the aftermarket ones? I'm looking at the Transgo Jr. kit for my truck and figrued I should look into a deeper pan for it as well if I have the stock one off. Or if there is an aftermarket one that a lot of you are using, I'd love to hear about that as well. Any info about this would be great. Thanks.
  2. saratoga
    saratoga Unpaid Help Staff Member Moderator
    4,539
    63
    May 3, 2008
    Lithia, FL
    The factory deep pan is the best bang for the buck if you want to increase fluid capacity. Don't expect it to drop your temps however... It increases the fluid capacity which just means that the fluid will take longer to reach operating temp. I've got some pics and will see if they're on this computer.
  3. 12ga diesel
    1,766
    29
    May 4, 2008
    McHenry,IL
    If you have a pic, I'd like to see it. If it doesn't lower temps though, I think I might just get an aftermarket one with the cooling fins on it.
  4. saratoga
    4,539
    63
    May 3, 2008
    Lithia, FL
    The pics I have are on my desktop at home in Tampa (I'm in Montreal right now). I'll post some when I get back tomorrow night.
    Just FYI: No pan will lower sump temperatures. That is a misconception; you need a larger cooler to see lower temps.
  5. Diesel Tech
    Diesel Tech Registered User
    98
    0
    May 8, 2008
    The aftermarket pans do not reduce the temperature any more than the factory deep one does from our testing. The Allison deep is the way to go but make sure you get the proper internal filter to go with it.
  6. jb23
    jb23 Recruit
    59
    0
    May 4, 2008
    Illinois
  7. BudTX
    BudTX Edjumacated Redneck
    Good call. Did you get the filter lock to go with that new pan and filter?
  8. Philbilly2
    Philbilly2 Just a speck on the wall
    Deep pan is about 53 dollars at an Allision dealer, then you also have to get the deep pan filter too, I think that was $27.
    I don't have pictures of my pan though. I have pictures of every other part of the Allisons I have rebuilt but no pan.... idiot.
  9. rdean
    rdean Recruit
    47
    0
    May 6, 2008
    The Allison dealer here had a package deal. It was basically change to the deep pan and switch to Transynd with no labor charges. So I made the switch and let them do the work.
  10. jb23
    jb23 Recruit
    59
    0
    May 4, 2008
    Illinois
    How much was your package deal
  11. hoot
    hoot Recruit
    150
    0
    May 10, 2008
    SE PA
    Here's a few small pics I had from days gone by
    [​IMG]
    [​IMG]
  12. Diesel Tech
    98
    0
    May 8, 2008
    If I remember correctly the deep pan setup uses 2 more quarts that the stock GM setup in the truck. I put one on all my trucks as it's cheap insurance and for the life of me I do not see why GM decided to shorten it for the pickups.
  13. rdean
    rdean Recruit
    47
    0
    May 6, 2008
    I want to say........$225?? Heck that was 1 1/2 years ago. I need to look it up.
  14. skiandplay101
    skiandplay101 Refugee
    19
    0
    May 10, 2008
    Tucson, AZ
    Don't forget the filter lock. I found out the hard way when the tranny guy that I used had no idea about what he was doing. Threw codes for three weeks and then put me into limp mode. I shoud have done my homework but I trusted the guy and paid for it later. $350 in labor and synthetic fluid to find out that my internal filter had fallen out of place. Acted just like a bad NSBU with the "Range shift inhibbeted" message and not shifting into gear.
  15. saratoga
    4,539
    63
    May 3, 2008
    Lithia, FL
    I haven't forgotten about this... still need to upload some pics of the pan from home.
  16. 12ga diesel
    1,766
    29
    May 4, 2008
    McHenry,IL
    Not too bad. I might swing past the Allison dealership this week and get what I need. Might have them do if they can get me in.
    So I will need the new deep pan, new internal filter, filter lock, and a new spin on while I'm there. If I end up taking it there for them to do, would they throw on the transgo jr kit you think?
  17. jb23
    jb23 Recruit
    59
    0
    May 4, 2008
    Illinois
    Only if you sweet talk them real nice
  18. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    i like that idea. i'm getting ready to switch to transynd, i suppose i might as well put a deeper pan on too.
  19. Chromer
    Chromer Ain't no Recruit
    56
    0
    May 10, 2008
    Northern Illinois
    Wow, that's a good deal. I'll have to check with my Alli dealer and see if they will honor that one!
  20. IdahoRob
    IdahoRob New Member
    8
    0
    May 12, 2008
    You do not need the filter lock with a factory deep allison pan. They were designed to work perfectly with the allison deep sump internal filter. The deep pans are on every topkick/kodiac without a filter lock. Now some aftermarket deep pans need the filter lock, but not the Allison.
Share This Page
