All 8 replaced
Discussion in '01-04 LB7' started by WanaDmxSub, May 17, 2008.
  1. WanaDmxSub
    WanaDmxSub Recruit W/gray hair
    89
    0
    May 8, 2008
    Just got my truck back today. Not sure how they did it...but they used bad balance rates on 2 injectors to replace all under the special policy. Also said they had to replace the sleeves. I did ask any questions...just happy to get the truck back with new (rem) injectors. Only thing I told them was that it smoked at idle. But I knew the balance rates were off also.
  2. SfcJones
    SfcJones A(ACLU) SGT. SLAUGHTER
    3,504
    12
    May 3, 2008
    South Ga.
    glad you were able to get a new set, hopefully this will be your last too,
  3. Hammer 4
    Hammer 4 Have Hammer..Will Travel
    241
    0
    May 5, 2008
    San Pedro, So Cali
    Wanna, how many miles on your truck...?
    Hope the new injectors work out for ya...:driving:
  4. WanaDmxSub
    89
    0
    May 8, 2008
    Truck will turn over 70k this week.
    I checked the balance rates today and they have never look this good..ever!
  5. Rhall
    Rhall New Member
    4
    0
    May 11, 2008
    Thats good, ive always heard everyone having bad luck with injectors, i guess ive just had really good luck, this is my second dmax and both have never been replaced. knock on wood...
  6. WanaDmxSub
    89
    0
    May 8, 2008
    Fuel system is 100% stock.
    Fuel filter changed every 5k.
    If this set last 4.5 years/70k like the last set (minus the 2 that were replace at 800 miles) that will put me out of warranty...time for more filtration...and maybe a lift pump:D
  7. malibu795
    malibu795 misspleelleer..........
    961
    0
    May 7, 2008
    south charleston ohio
    acording to the TSB
    injector rate
    fuel in oil
    hazy smoke at idle
    and a several other symptoms state ALL injectors get replace. the guys that have only getting a couple changed are getting screwed
  8. busdriver75
    busdriver75 Busier than hell...
    1,258
    0
    May 7, 2008
    NW Ohio
    where's your dealership at?? sounds like they were pretty good to work with, especially with all your mods.
    i've got a lopey idle lately, i'm wondering if i have an injector or two starting to go. hopefully i can get as lucky as you with service froma good dealer.
  9. malibu795
    961
    0
    May 7, 2008
    paradise chevrolet ventura california.
    i popsted both TSB for the INJ this a ecerpt about halve way down the mess
  10. busdriver75
    1,258
    0
    May 7, 2008
    NW Ohio
    thanks a lot. i want to be a very informed customer if i need work done.
  11. WanaDmxSub
    89
    0
    May 8, 2008
    Adam
    Where did you read "hazy smoke at idle" in the TSB/Special policy? I don't see it.
    Ryan
    It takes me 1/2 a day to get the truck ready for the dealer and then another 1/2 a day to put it all back...
  12. malibu795
    961
    0
    May 7, 2008
    i was quoteing fomr memory.. go through it again and check for the symptoms i could be worng about the hazy smoke
  13. WanaDmxSub
    89
    0
    May 8, 2008
    Smoke isn't one of the symptoms (but we all know what it means...:frown2:) for the special policy. If you follow the service manual it leads you down a different path to individual injector replacement.
Share This Page
