ABS light on
Discussion in 'Drivetrain' started by WPatrus, May 18, 2008.
  1. WPatrus
    WPatrus Flunky
    27
    0
    May 11, 2008
    Georgia
    My abs light keeps coming on and off. There seems to be a slight lack of pressure when I first apply the brakes. It does come back to full pressure but it isn't there when I first apply the brakes.
    Kinda feels like a vacum thing to me. Also I noticed last week that one of my brake sensors on coming off my hub was slightly warn I guess from a tire?
    I taped that up with electerical tape but it might also be contributing as well.
    Any ideas guys. Never been a brake guro myself.
    Thanks
  2. duramaxdiesel
    duramaxdiesel Recruit
    10
    0
    May 8, 2008
    When my ABS light was going on and off it landed up being my wheel bearing going south.
  3. WPatrus
    WPatrus Flunky
    27
    0
    May 11, 2008
    Georgia
    I just replaced my bearings a month ago - I found the problem though. The wheel speed sensor has rubbed up against the tire (I didn't tie it back enough). I have spliced, soldered and taped up the line properly but the light seems to still be on -
    I have cleared it now with EFI Live and if it comes back on I dunno where to go from here. Everything is working properly anyway.
  4. whitetrash21
    whitetrash21 Put on the damn helmet day........
    788
    0
    Apr 29, 2008
    Vegas
    wheel bearings are one reason. i got cracked pads on mine and those are settin it off. not often but enough to get annoying. loose wheel speed sensors, bad seals (rear) let fluid into braking system(e brake drums), bad abs motor (rare) are all reason for the light to kick on. check your fluid, might be reason pedal goes funny on you. pads could be stickin in the clips, might pull those out and scrub off any rust or grime on them. i did that to mine and it made a difference in braking. truck no longer pulls one way when i hit the brakes hard.....
    just a few things to check.
  5. WPatrus
    WPatrus Flunky
    27
    0
    May 11, 2008
    Georgia
    SO far so good after resoldering everything yesterday and clearing the codes with EFI Live. Turns out my problem was not tying the wheel speed sensor far enough out of the way.
    Thanks for the ideas guys - I glad this fixed it. I was getting tired of pulling these tires on and off the past few days.
  6. ripmf666
    ripmf666 Registered user
    687
    0
    May 10, 2008
    Kansas City Mo
    I just had the driver side bearing replaced now the abs stopped coming on started to think it was my Viper alarm
Share This Page
