abs light, 1995 k-3500 how to check why its on?
Discussion in 'Drivetrain' started by vaicase, Mar 20, 2011.
  1. vaicase
    vaicase New Member
    71
    2
    Mar 16, 2011
    morley michigan
    my 1995 k-3500 abs light is on. why. i went o reilys and the have a ob1 scanner. and it reads abs codes. it says my truck is not responding. it did say my truck was a 1995 so i think it reads my truck. just not the abs codes for some reason. i have an old obd 1 scanner and it has an abs swiutch. it says 73, then 86 then 12 then 25 then 35 then back to 73 and so on. i tried unhooking the battery for an hour. it will not clear. it does seem the rear braks do lock up. not the front. but that might be because it light in the back. thank you much.
  2. WarWagon
    WarWagon Well it hits on 7 of 8...
    7,379
    1,350
    Nov 15, 2009
    AZ
    ABS light means system ABS disabled due to a fault. Check wires to the sensors and then check the sensors and 'tone wheels' for rust and metal build up. The 1995 ABS systems had a defective spring clip in the motor causing module failure - may be under recall.
  3. vaicase
    vaicase New Member
    71
    2
    Mar 16, 2011
    morley michigan
    i checked the wires on the front ? it looks good. it seems the rear has no sensers on the whole system. no sensers in the whole rear setup, lines are just like a truck without abs. only one wire on each front wheel, so is there a way to check the codes? or is it either its on when something is wrong? or off when it o.k.? how does it reset? even if i find a problem? also how do i check for a recall? thanks
  4. JMJNet
    JMJNet Recruit
    1,916
    83
    May 6, 2008
    Richardson, TX
    Jump pin A and H in the ALDL connector and count the ABS light blinks.
    H is 2nd from the left on the bottom row.
  5. THEFERMANATOR
    8,503
    1,559
    May 9, 2008
    ZEPHYRHILLS FL
    Not of much help, but my 95 won't scan with a scanner either. I hooked it up to a TECH 1 and it wouldn't detect it. I ended up jumping the 2 terminals and counting the flashes, but this method I found gives LOTS of codes(some of which didn't even apply to my system).
  6. WarWagon
    7,379
    1,350
    Nov 15, 2009
    AZ
    Rear wheel is sensed off the VSS system: aka rear trans speed sensor. Switches for the 2/4WD mode were recalled as well.
    A phone call to the dealer with a VIN will clear up recalls. They had a reprogram sensitive ABS for different road conditions as a safety campaign to reduce stopping distances on some surfaces.
    In your case the system is seeing something wrong like a bad front wheel sensor including wiring to the sensor, corrosion, broken/metal plugged/missing tone wheel on the hub and possibly bad hub bearings on the front. The ABS unit itself could have problems and this is where code retrieval will point you in a good direction.
    Unplug the front wheel sensors and do an ohm check of them, wiggle the wires and see if it changes the ohms.
  7. JMJNet
    JMJNet Recruit
    1,916
    83
    May 6, 2008
    Richardson, TX
    Measuring the resistance in the front wheel sensor (both sides) can determine the failure also. IIRC, it should show some ohm like >1000 ohm. The bad one shows 0 ohm.
    The connector is behind the rubber flap of the wheel fender.
  8. bison
    bison Well-Known Member
    I have the same thing on my 95 for 1/2 a year,ABS light on
    Am doing the brakes on it now,so decided to look at the wheel sensors.
    one measured around 1000 OHM,the other zero.
    Now the best part.
    Phoned two diff out fits for a new sensor. One wants $140, the other $190.:eek:
    That's F"cking robbery :rolleyes5: :mad2:
    Sooo!,to hell with the ABS,i'm gonna pull the plugs.
  9. davo727
    davo727 Member
    471
    2
    May 28, 2008
    Cleveland, Texas
    My darn 95 k2500- I jumped the ALDL pins A to H and I get nothing, no flashing abs light for a code , just stays on solid abs light.
  10. davo727
    davo727 Member
    471
    2
    May 28, 2008
    Cleveland, Texas
    It is popping a 10 amp brake fuse # 18 in the little fuse panel on the drivers side of the dash. I pulled all the connectors off the abs pump and it still pops that fuse as soon as I turn the key to on. Time to chase wires I guess.
  11. hondacop
    hondacop New Member
    2
    0
    Mar 22, 2011
    upstate NY
    You may have bad bearing(s) in the front hub. This is a frequent cause of abs light as worn bearings affect the gap on the sensor.
    Brad
  12. vaicase
    vaicase New Member
    71
    2
    Mar 16, 2011
    morley michigan
    i checked the resistance. and the right is 2.8 the left totaly zero. now what?
  13. hondacop
    hondacop New Member
    2
    0
    Mar 22, 2011
    upstate NY
    I would take the truck for a ride on a smooth road and listen for a noise from either side of the front end, If the bearing is going out you may hear a humming noise which may change as you turn.
    If this is the case you probably have a bearing failing in the hub assembly. Most often (but I don't know for your particular model) the hub assembly changes out and includes a new abs sensor and cable. I would check for sure--the parts guy..or girl will know.
    If you have to change it I would have a ox-acet torch handy as you probably will have to pull the caliper hanger and the can be stinkers sometimes. Just did 2 on my son's Jeep.
    Good luck.. let us know how you make out.
    Brad
  14. jrsavoie
    jrsavoie Recruit
    5,367
    374
    May 8, 2008
    Rural Clifton, Illinois
    How did this end up? I am having the same issues. I tried a used sensor - I have a couple laying around
  15. Big T
    Big T Well-Known Member
    2,997
    329
    Sep 25, 2009
    Fullerton, CA
    You can the entire bearing hub with new sensor for $190. Rockauto sells the senders for like $30.
  16. vaicase
    vaicase New Member
    71
    2
    Mar 16, 2011
    morley michigan
    I just pulled the abs fuse under the hood, and put tape over the light. Done
    Carl4x415004.3 likes this.
Share This Page
