a-piller vs. overhead mount
Discussion in 'Interior Components' started by MattZ71, May 18, 2008.
  1. MattZ71
    MattZ71 Tennessee Diesel's Mod
    355
    0
    May 16, 2008
    KY/TN line
    ok guys, which of yall have the a-piller or overhead mount? which is easyer to install and esayer to see?? OH and how many of you use the TTS dash pocket mount.....do u like it?
  2. Grendahl
    Grendahl Does not play well with others
    217
    8
    May 1, 2008
    Syracuse, NY
    I have both. The A-pillar mount holds the boost and EGT gauges, the overhead "Trippen" mount is for the rear air bags and compressor gauges. The a-pillar is definately easier to see. I think the ease of installation is about the same for either. There are a couple of pictures of my setup in my photo album.
  3. WhitetailAddict
    WhitetailAddict Recruit
    260
    0
    May 9, 2008
    Central Pennsylvania
    I believe the a-pillar are easier to see. That is why I have the pyro and boost in there. I plan on putting the fuel pres. and oil temp/or oil pres. in the trippin mount.
    I don't like the idea of the factory a-pillar needing to be used on the Autometer pod. I would have preffered a full replacement like is available for the other makes.
  4. DunesRunner08
    DunesRunner08 Banned
    1,417
    0
    May 7, 2008
    Phoenix, AZ
    the a pillar are easiest to see but the overhead look cooler....
  5. Hammer 4
    Hammer 4 Have Hammer..Will Travel
    241
    0
    May 5, 2008
    San Pedro, So Cali
    Pillar here...my Old eyes can't the gauges to well on the overhead spot..:eek:
    If your doin a 3 gauge set up, the pillar is the way to go, but if your doin the boost and pyro, then it's your choice. If I could have seen the overhead gauges well enough, I woulda put em there.:D
  6. MattZ71
    355
    0
    May 16, 2008
    KY/TN line
    thinks guy for the input! but i was look, and for $$$ reason's i may have to go with the over head trippin mount
  7. WhitetailAddict
    260
    0
    May 9, 2008
    I believe the trippin mount is more $ than the a-pillar. Not completely sure though, once you figure in the paint for the a-pillar. Just a heads up.
  8. Drew
    Drew <font color=blue>Capa'n</font>
    1,585
    0
    Feb 10, 2008
    Dayton Ohio Area
    I went with the overhead mount for my gauges. I didnt want anything in the a-pillar that would give away to anyone that I was "modified" until it was too late :)
  9. Sparky8370
    Sparky8370 Do chickens have large talons
    1,703
    0
    May 3, 2008
    New Hampshire
    I got a 3 gauge pillar mount with 3 guages (Came with trans temp, boost and pyro, I still have to return the trans to get an oil temp or something) for $189 It's a 7 color led deal. I have my pcds-9 controller in the overhead.
  10. Hammer 4
    241
    0
    May 5, 2008
    San Pedro, So Cali
    Trippin's mount is about 125.00...Autometer pillar is about 80.00 IIRC. Paint is around 7-8 bucks.
  11. MAX4X4
    MAX4X4 Recruit
    54
    0
    May 4, 2008
    CA
    I have the overhead and it works great!
  12. KYLE@XDP
    KYLE@XDP can help you w/ anything
    200
    0
    May 9, 2008
    NJ
    we have the overhead a little cheaper than that ;)
    i have the pillar and my boss has the overhead both w/ the edge, personally i can't stand the overhead you really gotta take your eyes off the road to look at it.
  13. minisub
    minisub 6-5/6-6;Whatever It Takes
    272
    0
    May 5, 2008
    The Northcoast, Ohio
    Then there is the over mirror option. Doesn't mess up visibility around the a pillar and is much easier to see than the overhead.
  14. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    i have the a pillar and the over head/over mirror mount that mini sub speakes of. personally i would do the autometer over head that i have. i find i look there easier than the a pillar. but it is personal preferance. it fits nice and is a no cut or screw mount.
Share This Page
