    CLICK HERE TO REGISTER! Problems registering? Click here to contact us!
94 Chevy Crew Cab 4x4 Dually
Discussion in 'Closed classifieds' started by tanman_2006, Jul 9, 2010.
Thread Status:
Not open for further replies.
  1. tanman_2006
    tanman_2006 Just a farm kid...
    Feb 15, 2010
    5,050
    43
    Seiling, Oklahoma
    I called the guy and got some info from him.
    Truck has ~150,000 on it and had a GM Crate engine when he bought it. Soon after he bought it he was gettin coolant in the oil and immediately bought a reman 506 engine (i assume this because he said it required HO oil pump). After he pulled the old engine he realized the head gaskets where bad, everything else is fine. Went ahead and put the reman in and has the Pull Out for sale.
    After he got a running engine he took it for a drive and the CEL came on, he went to clear it and was told the IP was bad (maybe PMD he doesn't know what PMD is). After that he said the truck stopped shifting right and sometimes wont come out of 1st but he can shut it down and start back up and be fine.
    I want a newer 96 and up so I pass this to everyone here.
    http://oklahomacity.craigslist.org/pts/1828682081.html
  2. buddy
    buddy New Member
    Nov 12, 2008
    6,093
    4
    California, central coast
    You get the long block with it!
    Thats a good deal, although someone put the wrong bumper on it, obviously not knowing it was different. Maybe it was replaced because of accident that also led to engine replacement. And lack of air to the filter probably led to head gaskets blowing.
  3. tanman_2006
    Feb 15, 2010
    5,050
    43
    Seiling, Oklahoma
    He says the engine was original that he took out but the sticker on the valve cover says otherwise.
    Does the air from the snorkles go to air filter?
  4. 625fireman
    625fireman I have injecter-itis
    Dec 10, 2008
    1,038
    0
    NE Ohio
    Yes and no
    They just bring more air in behind the grill and core support which is where the air intake is. They don't directly "funnel" air into the air filter.
  5. Acesneights1
    Acesneights1 New Member
    May 5, 2008
    10,048
    3
    Northeast CT
    Yeah but the wrong bumper will blow the motor for sure...:rofl:
  6. buddy
    buddy New Member
    Nov 12, 2008
    6,093
    4
    Maybe it can Kenny, maybe it can
  7. WarWagon
    WarWagon Well it hits on 7 of 8...
    Nov 15, 2009
    5,750
    88
    AZ
    Lots of air is scooped up by the bumper cutouts. Then directed by the special plastic pan just behind the bumper with the one PIA door for oil cooler line changes.
    Hard work the factory cooling system is not up to it. Reducing the amount of air from the bumper... Lets hope this truck did not work hard.
    I have a blown 6.5 that lack of cooling was the cause.
  8. jrsavoie
    jrsavoie Recruit
    May 8, 2008
    4,647
    20
    Rural Clifton, Illinois
    From what I could see it looks in good shape for a 94
  9. jessejames88
    jessejames88 New Member
    May 31, 2009
    10
    0
    ny
    got the same truck with the same trans issue... mines got a gasser front bumper... dont run hot though even towing... been meaning to change it though gotta find a deal on one first bumper may cause the limp mode on the trans though...
  10. bk95td
    bk95td 6.5 nut job/addict
    Nov 26, 2008
    2,599
    2
    The 97 c&c in my sig has a gasser bumper. It broke a piece of exhaust valve and pounded it into the piston and cylinder wall. It WILL have nostrils when it gets a engine.
  11. tanman_2006
    Feb 15, 2010
    5,050
    43
    Seiling, Oklahoma
    The guy pulled the engine and sold the body/frame engine is still for sale though.
  12. great white
    great white Active Member
    Apr 26, 2010
    3,931
    4
    400 bucks for a good long block?
    I'd be all over that.....
Thread Status:
Share This Page
