68RFE
Discussion in 'All Other Transmissions' started by gmctd, May 4, 2008.
  1. gmctd
    gmctd Diesels, Anonymous
    565
    0
    May 3, 2008
    texas
    In this thread, I will be detailing the installation of the '07.5 Dodge 68RFE 6-speed automatic into my '96 Dodge 12v - the instructions should be compatible with any chassis not using the 6.7 engine - at present, all the pieces are gathered, and each challenge is being addressed as it arises - pics to follow...........
    Here's what I saw:
    [​IMG]
    Here's what I got - build date on this 5000mi unit is NOV 06 - note the input and output shaft speed sensors, for accurate torque management - that's the dipstick, sans fill tube:
    [​IMG]
    Note the 1/2" cooler line ports - that's the pressure sensor connector at the back of the case
    [​IMG]
    Input shaft is 1.1"dia across the 26splines, 1.054"dia behind the spline - the large plate covers the dual-output pump and seals the end of the case
    [​IMG]
    4wd tailshaft final inspection 335th day of '06 (Nov 06), laser etched - output shaft is same dia and spline as NV4500 and NV5600 @ 1.425"dia - 4wd adaptor flange dia and bolt-pattern fits both NP241 and NP271 transfer cases
    [​IMG]
    Here is the very aggressive 13"dia t\c - the four flats drive the input gear in the pump - note the seal on the drive hub, also that it is silicone compound
    [​IMG]
    [​IMG]
    Also required: larger 'cooler with larger pipes
    First problem, e pluribus unum, is the pilot diameter in the 6.7 crankshaft is 2.130" while the 5.9 is 1.810" - this will require machining the 68RFE pilot hub to 1.810" to fit the 5.9 flexplate - the t\c-to-flexplate bolt pattern and bolt circle diameter is identical - I'm using the aftermarket 30% thicker flexplate - Suncoast has indicated they will build t\c's to match, as required
    tbc................
  2. gmperformance03
    gmperformance03 Recruit
    7
    0
    May 6, 2008
    Michigan/Indiana
    I'll be following this thread closely...hopefully everything goes pretty smoothly, as I might do this conversion in the near future.
    Thanks for starting this thread! Good Luck with everything
  3. THEFERMANATOR
    8,820
    2,021
    May 9, 2008
    ZEPHYRHILLS FL
    How many splines is the output shaft? When you get the 47 out can you get us a side by side with the 68? It's nice to see somebody tackling this.
  4. KYLE@XDP
    KYLE@XDP can help you w/ anything
    200
    0
    May 9, 2008
    NJ
    sweet sounds like a cool project.
  5. gmctd
    565
    0
    May 3, 2008
    texas
    Spline config is same as NV4500, NV5600, NP241DHD - 241D from the 47Rx\47RE just requires the larger input hub from the HD version
  6. gmctd
    565
    0
    May 3, 2008
    texas
    '05 48RE input shaft is 1.040"dia across the 23 splines, base shaft dia is 0.825"
    '07.5 68RFE input shaft is 1.100"dia across the 26 splines, base shaft dia is 1.054"
    Output shaft is 1.425"dia, same as the NV4500 and NV5600
    Doesn't seem as much of a 'joke' as some have stated, right? Only the optional Aisin AS68RE offers more torque thruput, and that is currently offered only in the cab'n'chassis series behind the 6.7
  7. 05_CTD_CalebS
    05_CTD_CalebS New Member
    22
    0
    May 17, 2008
    West Lafayette, IN
    This looks like a great project and I will be keeping an eye on this..thanks for the info :yesnod::yesnod:
Share This Page
