500hp
Discussion in '01-04 LB7' started by 03demax, May 12, 2008.
  1. 03demax
    03demax New Member
    57
    0
    May 7, 2008
    If I add a lift pump and EFI live and run one of the 500hp tunes out their how long will my engine take it? :)
  2. stacks04
    stacks04 McLovin
    3,579
    0
    May 9, 2008
    terryville ct
    depends on how much you beat the crap out of it. if you drive it 500hp everytime you take off from a light. it is a crap shoot.
  3. WanaDmxSub
    WanaDmxSub Recruit W/gray hair
    89
    0
    May 8, 2008
    Lots of variables, but 500rwhp is typically considered to be on the safe(r) side.
  4. emerson
    emerson Ugly is cheap
    92
    0
    May 9, 2008
    Prince George BC
    Your trans is built, right?
  5. srode
    srode Too many toys
    84
    0
    May 8, 2008
    Iowa City
    It will take it longer than your tires will. :wink5:
  6. 03demax
    03demax New Member
    57
    0
    May 7, 2008
    I need a built trans but I just wanted to ask the question about my motor.
  7. Horsehaulin
    Horsehaulin Recovery Expert
    55
    0
    May 10, 2008
    Fort Wayne, IN
    Mike L. drives his truck with 500RWHP everyday, and upon talking to him it doesnt sound as if he is too kind to that truck. There are plenty of trucks of each varient that are running 500RWHP or more everyday and they use them that way. If Nasty Girl can go 20K miles at well over 1000RWHP and not have a failure, I am sure your truck can take 500RWHP for much longer and survive just fine.
  8. The Killing Road
    The Killing Road Banned
    597
    0
    May 10, 2008
    MS
    I'm in that ball park and I have 180K on the truck...but I baby it....
  9. Smokin LB7
    Smokin LB7 Just Takin' it From a Dig
    34
    0
    May 13, 2008
    Greeley, CO
    Nasty girl's motor is built to shit though at the same time. I agree it is doing phenomenally well, but i guarantee it wouldnt be the same story if it wasn't built
  10. jcool
    jcool #78 A(ACLU) FNG
    1,097
    0
    May 4, 2008
    Richlands, NC
    your motor should be just fine, factory turbo will only maintain roughly 30psi for a short life. I saw a 01 with 450k on the odo, with a chip and some other stuff.. maybe 400 at the wheels... but its had a head gasket, and a set of injectors. but then again, every truck is different!
  11. ZF6 MAN
    ZF6 MAN The Unwritten rule
    30
    0
    May 3, 2008
    you should be ok but as you know the tranny will need severe work and remember to use your head with the turbo. Bear in mind NastyGirl had BIG money inthe engine and is NOWHERE near stock
  12. sparky1562
    sparky1562 Just a hack
    17
    0
    May 11, 2008
    Middle TN
    And Even Nastygirl had problems recently...
    If you wanna play, sooner or later you gotta pay!
  13. WI Huck
    WI Huck New Member
    3
    0
    Jun 29, 2008
    I ran 500 rear wheel HP for a few years. The engine had 100 K plus miles on it when we tore it down to upgrade the internals. Everything was fine, except the cam pin was smushed over badly and about to break off. Durability has a lot to do with who made the tune, since they are not all the same.
  14. JustinD
    JustinD New Member
    22
    0
    Aug 15, 2008
    Thats what I'm aiming for hopefully it holds up for a while!
Share This Page
