2008 3800 Express 6.0 w/ 4L80E 7000 Miles
Discussion in 'Introductions' started by wyrmrider, Oct 20, 2016.
  1. wyrmrider
    wyrmrider New Member
    29
    5
    Oct 15, 2016
    los angeles
    Anyone know where the build data plate is on one of these? not in dash
    Planning to change all fluids
    Allison 295 in the trans (much better than Dex VI) and steering/ power brakes
    DOT 4 for the brakes
    Guess I'm stuck with Orange Dexcool
    add coolers for trans (has a wimpy one) and engine
    I have found that for trans 1/2 inch lines flow much better than 3/8- will add a filter
    IDK about engine yet will uses stacked plate coolers IDK about lines yet
    notice lack of baffles between grille and radiator allowing air to flow out wheelwells and not through the AC and Radiator
    It has new tires- not my choice but OK
    any suggestions appreciated, I will start a thread if appropriate
    tks
  2. btfarm
    btfarm 330,000 Worth and counting Staff Member Moderator
    16,577
    2,330
    May 12, 2008
    Sandwich, Illinois
    Welcome to the Truck Stop!
  3. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    Thanks
    found some lug nuts rounded off- at least I'm not on the road
    are they Metric? 7/8 seems loose
    calipers in hand
  4. ak diesel driver
    ak diesel driver 6.5 driver
    12,753
    2,756
    Feb 7, 2009
    alaska
    should be either 21 or 22mm
  5. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    yep= 22mm
    yahoo with an air wrench and 7/8 really did a number on them some not even close to torque New Tire guy gets to buy some new ones
    posted this in the wrong thread
    thanks
  6. THEFERMANATOR
    8,975
    2,299
    May 9, 2008
    ZEPHYRHILLS FL
    7/8" is basically 22mm(within a few thousandths of each other). The 2500/3500 lugnuts with the hubcaps and the thread on nuts should be 21mm, 1500's are 22mm.
  7. NVW
    NVW Well-Known Member
    8,690
    1,292
    May 5, 2008
    Castor, AB.
    I've never used anything other than a 7/8" socket. Maybe a 12 point socket was used on them.
  8. Will L.
    Will L. Well-Known Member
    7,396
    5,986
    Jan 25, 2013
    Boulder City Nv
    Same, and everyone in the fleets I worked with. Thousands of tires changed. No issues.
  9. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    got out the mic 22mm
    21 will not fit, can't find my 22
    it's about .010 different than 7/8
    I tried a craftsman 6 point 7/8 and it would not get the rounded off one off
    I'll try a good 22 6 point when I find mine or I'm off to Sears tomorrow
    not something to try Harbor Freight on
    good point about the 12 point NVW thanks
    otherwise it's plan B the air chisel
    still glad I'm in the driveway and not half way to nowhere
    I'll try and take all the other ones off first and try and get the rim to move
    sometimes that helps
    thanks guys
  10. THEFERMANATOR
    8,975
    2,299
    May 9, 2008
    ZEPHYRHILLS FL
    Then I must have gotten them backwards. Could have sworn I used a 21 on mine.
  11. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    I pulled the hubcap off the other front- looks ok
    now tomorrow the rears
    Have not found my 22 so go get one tomorrow
    would like to get the rounded one off without total destruction
    holding a new Craftsman 21 in my hand as we speak but too dark to try tonight
    I'll double check tomorrow
    21mm is .8268
    22 .8661
    7/8 .8750
    will advise
    Have not found my 22 so go get one tomorrow if 21 is a no go big difference almost .040
  12. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    REPORT
    Bought a new 22mm six point impact socket
    virtually NO wiggle
    7/8 six point has considerable wiggle
    7/8 12 point would strip
    I replaced the stripped nut as it had considerably more slop than the good nuts
  13. wyrmrider
    29
    5
    Oct 15, 2016
    los angeles
    Anyone know the procedure to R&R the front bumper valance, time for a new one
    tks
Share This Page
